Error Connecting to BB
Discussion in 'Control Software' started by AJ Kaddoura, Mar 22, 2021.
  1. AJ Kaddoura
    Hello all,
    I recently hooked up my BB and im getting errors connecting to it.
    at the beginning i thought maybe wiring mismatch so i unhooked everything except the USB port flashed and tried to connect. still getting error.
    Even attempted different ports and reinstalling drivers. no luck.
  2. sharmstr
    The only thing you didnt mention out of the troubleshooting steps was trying a different USB cable. Have you? If so, contact the store.
  3. AJ Kaddoura
    Would the flashing work even with a faulty cable? because it worked
  5. AJ Kaddoura
    Except, Reread section 6.3.6 - you should contact the Store, not post on the forum. Different entities, different teams. Forum doesn't have access to order history, warranty info, or ability to resolve warranties. You also probably wouldnt want to discuss private details like shipment addresses and order details in a public forum. Best to please contact the Store
  7. AJ Kaddoura
    I appreciate the help. and i did contact the store. i was just asking if anyone has come by this issue...if its known...if anyone has some workaround....but yea...
    Unfortunately no workarounds that arent already encompassed by the docs. If the usual issues listed in the Docs does not help, then it usually relates to an earlier wiring mistake causing permanent damage, or other similar accident at the root of it all. Best to let the Store work with you on this.
  9. AJ Kaddoura
    Alright...im not gonna bother re-explaining everything. i appreciate the help.
    no need for the condescending tone. Please compare my issue with the docs then refer me to the docs. the whole point is that my issue doesnt match the docs 100%
    #9 AJ Kaddoura, Mar 23, 2021
  10. AJ Kaddoura
    Nevermind. i have found a solution for my issue. hit me up for details.
  11. Peter Van Der Walt
    Please do share, if only to help the next guy
