Similar to error:22 - Gcode from Vectric? Which post processor are you using? Post the vectric project, post you used and resultant gcode.
Suspect recent major Vectric upgrade - did you migrate everything (especially post processors) from your previous version if this might apply to you? Alex.
Yes but vectric updates may have overwritten your old one. Try the mm one, lets see if that helps, then we ask Vectric to look at the Inch one if that is the case... you can only help troubleshooting by following the suggestions please
This is the "old" inch post processor from Vectric - I haven't had a chance to test it. Alex. PS Vectric claim the latest release (today) fixes the problems with the grbl post processors. It doesn't mention Openbuilds or Duet versions.
