error 9
Discussion in 'OpenBuilds Bug Report' started by Jamie 007, May 3, 2021.
  1. Jamie 007
    Jamie 007 New
    good evening guys new to the forum, i have a openbuild 1010 machine running a dewalt router i constantly get the code below can anyone point me in the direction to figure this out before i negotiate with a bat on it thanks
    error: 9 - G-code locked out during alarm or jog state [ G1X288.579 ]<hr>This error may just be a symptom of an earlier event:<br> ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
  2. sharmstr
  3. Jamie 007
    Jamie 007 New
    i am also getting an alarm 1 code
    [19:37:04] [ G1Y147.955 ] error:9
    [19:37:05] [ ] error: 9 - G-code locked out during alarm or jog state [ G1X79.239 ]<hr>This error may just be a symptom of an earlier event:<br> ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
    [19:37:05] [ ERROR ] error: 9 - G-code locked out during alarm or jog state [ G1X79.239 ]
  4. sharmstr
    Is your router power cable in the cable chain, right next to low voltage limit switch wiring? Mains cable crosstalking into signal cables is no 1 cause of EMI.
    Take it out. Build a swing arm:
  6. Jamie 007
    Jamie 007 New
    The rotor cable is about 2 " from it . I turn the rotor around . l give that a try
    thank you
    Jamie
