error 22 in the middle of cutting
Discussion in 'CNC Mills/Routers' started by mlowka, Sep 27, 2020.
  1. mlowka
    mlowka New
    Hi- I've been using cut2d for a few months now and everything worked fine so far.
    Today machine stops working after cutting half of a project and error 22 occurs. I didn't change the settings, and the problem appears every time now. Any ideas what may be the cause?
  2. Rob Taylor
    Look at the line at which the error occurs and paste here the the 10-20 lines before it and maybe 5 lines after.
    If it successfully G1 cuts for 20 minutes or so and then randomly forgets the modal feedrate, that seems odd. If the post isn't including any F number at all, it should error 22 right near the beginning of the program.
    Only thing I can think of is it's internally splitting up an operation and then resetting the feedrate to F0 for some UI-related reason.
  3. mlowka
    mlowka New
    Problem solved- broken USB port :)
