Error 2
Discussion in 'OpenBuilds Bug Report' started by jltcet, May 20, 2024.
  1. jltcet
    jltcet Well-Known
    Ive been running into this error #2 a lot when getting ready to run a projects the Openbuilds interface. I have to keep trying several times to make it work. I looked up the error code and get 2 different answer's so not surte which is correct. Like I said I can eventually get it to work but it throws this code several times befor it starts to work. Any Ideas why this is happening. If its really something to do with the travel. Then the machine is really messed up because the travel has always been fine.
  3. jltcet
    jltcet Well-Known
    Controller is up to date and its not just this file its any file, I have to try 3 to 4 times to make it work Thanks for your help
    As a test, run the same files from the PC for a bit, EMI is a little more likely to affect Interface (long cable, better antenna) so that might confirm if its EMI related.
    If it is, addressing the source is key. VFD spindle / Plasma or similar in use?
  5. jltcet
    jltcet Well-Known
    So your saying the long cord that comes with the Openbuilds controller my be a culprit (Possibly) I'll run the test using the computer and not the controller and see what happens. Let you know when Im able to do it. and the results. Thanks
    Not at all.
    I am saying it makes a good test to see if you have an EMI issue elsewhere. Then we fix the SOURCE of that EMI (Spindle, Plasma, whatever). Long cable is fine - but if you have EMI (you shouldn't) it would catch it a little easier
    And then only IF it is PC vs Interface showing PC wins. If same issues come up on PC its something else.
    Cart behind the horses (;
    Test 1
    Depending on its results we'll take it further
  7. jltcet
    jltcet Well-Known
    Ok got what your saying now. ok I'll let ya know what happens. Thanks
  8. jltcet
    jltcet Well-Known
    Ok so today I fired up the machine and it didn’t fault or error at all so IDK I’ll try something else see how it goes
  9. jltcet
    jltcet Well-Known
    Ok so today when I fired up the cnc it gave me the error code 2 again. And I thought about it for a minute, and realized the project I ran the other day was made with F-360 ever time I get an error code it from a design from Eseal only. IDK if that makes any sense to anyone but that what’s happening no errors with F-360 just Easel. Any ideas
    Post a sample of the non working file. Perhaps they aren't 100% grbl compatible, Error 2 relates to incorrect gcode.
