EMI Ferrite and GRBL
Discussion in 'Laser Cutters' started by syl, Mar 9, 2019.
  1. syl
    syl New
    Ferrites help filter high frequency EMI very succesfully.
    But a good RC filter as a first line defense is even better: Solving Endstop Woes with a Simple Analog Filter
    both together - can run withing half a meter away from my cheap junk plasma inverter with HF start (;
  3. syl
    syl New
    Blackbox supports inductives natively, plug and play! Check the documentation :) docs.openbuilds.com/blackbox
    No need for a adapter kit as in that link! Expensive! We added the components onboard already (why they charge $70 for $3-6 sensor, and diode or two resistors, plug and 3d printed box (maybe another $0.60) baffles me. Faith in humanity lost lol. We added them onboard for you as its literally a few 0.01s lol
  5. syl
    syl New
    Thank you Peter!
    BTW are inductive sensors susceptible to emi interference like the mechanical endstops?
    About the same, its the wires that act like antennas (;
    But the Blackbox filters basic EMI via an onboard RC filter (;
    Well, about the same can be rephrased to, about the same as properly wired mechanicals... Depending on the type and config, inductives might be way better come to think if it.
