Eliminate Supports with some kind of foam
Discussion in 'Concepts and Ideas' started by BillEgge, Jul 27, 2022.
  1. BillEgge
    BillEgge New
    Sometimes I winder if the hot end can melt its way through styrophome but still leave some to act as support for what your priniting.
    too hot I think, the foam will melt back far beyond what you want, hard to predict
  3. Rob Taylor
    Yeah, the foam near where it touched contracts away from the tip as well- you can see this if you do foam sculpting with a soldering iron or hot knife. It's also incredibly toxic to be basically burning styrofoam in the shop, so not the best plan.
    I think some kind of monolithic support structure is a good idea, I've had the idea before as well- non-printed supports would allow some really wild structures at a whole range of scales. Not 100% sure what it would look like- a fine powder that gets layered in would probably get aerosolized by the moving head and require heavy vacuum for safety, and a liquid would likely distort parts through both heat conduction and wave propagation from the moving parts.
