easel and openbuilds
Discussion in 'Other Software' started by Bober55, Dec 16, 2020.
  1. Bober55
    Bober55 New
    DSC_0825.JPG DSC_0824.JPG DSC_0823.JPG Hello
    i use easel as cam and it imports gcod into openbuilds
    in easel, this project takes almost 2 hours and imported gecode into openbuilds 3 hours
    what is it? please help
    Both are estimates. Real world runtime will also be another different figure. All depends on machine acceleration etc causing variance
  3. Bober55
    Bober55 New
    OK, got it, thank you
    And does this sculpture last that long, is it normal?
    900/450mm plywood 3mm thick?
    How long does normal take? Do other large-scale sculptures of this type last so long?
    #3 Bober55, Dec 17, 2020
  4. Giarc
    Judging by the first few lines of your Gcode your feed rate is only 800mm/min (F800) and plunge rate is only 228.6mm/min F228.6). I cut aluminum faster than that. If this is on wood, and if you are using any of the OpenBuilds machines, you should be able to cut at about 2500mm/min. You are also only cutting 1mm deep per pass. I could not tell what size of endmill you were using because it is not in the Gcode header but if using a 1/4" (6.35mm) endmill you should be able to easily cut 3mm deep per pass. If it is a lot smaller, than you may only be able to safely cut 1mm per pass.
    You are getting long cut time estimates because you are cutting so slow (F800) and taking shallow passes (z-1.000).
    When I edited your Gcode and replaced all F800s with F2500 and all F286.6 with F1000, the online simulator I use said it would take 40 minutes and 5 seconds. But as Peter said above, your acceleration settings will affect the accuracy of these estimates.
    #4 Giarc, Dec 18, 2020
  5. Bober55
    Bober55 New
    many thanks for the replies
    I have x-carve based cnc with 6mm stripes so this speed will probably be too fast
  6. Giarc
    Try a small project at 1500mm/min. I bet it will do just fine. Then speed it up a little more until you find its limit.
  7. Bober55
    Bober55 New
    Thanks, I know everything. Thanks for the valuable tips
