Duet Controller/Fusion 360 post fix
Discussion in 'CAM' started by Alex Chambers, Jul 21, 2019.
  1. ian McFadden
    Agreed access to the parameters and notification of your current offset would be a godsend but does not seem to be available on the Duet.
    The changes to g10 are discussed on the duet forums here. Agree its not NIST (but very handy:)). It doesent seem to be in the Wiki yet.
    I used VS code to build the zip, but first i used a text editor on the Appxxxx.js file in the www/js folder on the sd card. If you remover the tar,gz the system will use the uncompressed file you may have edited.
  2. GeoffH
    GeoffH Journeyman
    Thanks, I hadn't seen that, I'll modify my macros.
  3. Ryan Lock
    Ryan Lock Veteran
    Hi,
    I have just found this thread. If anyone still has any questions which need answering please let me know :)
    Ryan
    GeoffH likes this.
  4. GeoffH
    GeoffH Journeyman
    Hi Ryan,
    I've been using 1.0.7 Beta for some time and for my single WCS applications it's much easier to use and a great improvement over the 3d printer DWC versions.
    For a typical new part, I can now
    1) Power on, HomeXYZ
    2) Jog to corner of workpiece (I don't have a corner probe)
    3) Z Probe for tool length (I have a Z Probe macro that Sets the XY workpiece zero as well as the Z, so no SETXYZ needed)
    4) Run the Program
    Perfect (less is more) for most things that I do.
    The hard-coded G53Z94 in the Goto Work Zero, isn't correct for my C-Beam machine, fortunately my maximum Z is larger, otherwise the machine would go out of limits, but that's only a minor detail. Maybe a macro could be used, unless you can read the Z after the Home macrocall ??
    Anyway, I've just spotted that you have Beta2 since 23/08, I'll install that tomorrow.
    Good to see you on this thread!:) Geoff
  5. GeoffH
    GeoffH Journeyman
    Hi Ryan,
    I have done some tests of DWC 1.0.7 Beta2; looking very good so far, here are a few questions and requests:-
    1) What is the large "Compensation & Calibration" ComboBox above the Jog Controls to be used for?
    2) A display of programmed Spindle Speed RPM, optionally with the corresponding Makita or Dewalt rotary dial number would be nice.
    3) Could the feedrate units be displayed in mm/min or in/min since these are the standard units of the F address (NIST), or maybe a Settings option to display units/s or units/min?
    I think wherever "Speed" is written it should say "Feed" or "Feed Rate"
    4) The feedrate over-ride (Speed Factor slider) doesn't take effect until a number of moves in the Gcode buffer are completed , which can be long and too late to avoid cutter, workpiece or machine damage. I see that the DWC is sending M220, so presumaby this is a Duet Firmware issue.
    5) Z Babystepping is a very useful function, but I think "Adjust Tool Length Offset" or similar would be a better title for the WorkBee, probably an age thing!
    6) For advanced users with multiple vices or other hold-downs, multiple WCS would be beneficial and Fusion 360 caters for this, although so far as I know Vectric software doesn't.
    Ian McFadden has suggested and implemented a current WCS scenario for the DWC whereby WSC selection would be manually via the GCode console. The Fusion360 post-processor will output with all appropriate WCS codes. This scenario also works for the solitary G54 which is default, and would require no further input.
    Geoff
    ian McFadden likes this.
  6. Ryan Lock
    Ryan Lock Veteran
    Hi @GeoffH
    Thanks for the feedback some great suggestions in there:
    I will see have the Go To Work Zero command, and probably change this to either a macro file or system file so it can be customised.
    1) This be used when we introduce our touch probe, i am still too delve into that and remove what is not needed
    2) Now on my TODO List
    3) Also Now on my TODO List
    4) I probably can't change this as i think it is firmware, but i will double check
    5) Thanks for the suggestion, i will see if it can be renamed better.
    6) Working on this as we speak in the interface via a dropdown list above the movement commands :)
    Ryan Lock
    GeoffH and ian McFadden like this.
  7. Alex Chambers
    Hi Ryan, I'm afraid I disagree with Geoff on some things - I would very much prefer to use macros rather than have things "hard-coded" - so that I can easily tinker with things and change them to what I want. I can cope with macros, but don't want to re-write the firmware if I want to make changes. I haven't had a chance to play with this yet, but from what I've seen on this thread developments look really exciting.
    Alex.:thumbsup::thumbsup:
  8. GeoffH
    GeoffH Journeyman
    Alex - I am not in favour of hard-coding, I think you misunderstand - Geoff
  9. Alex Chambers
    Highly likely @GeoffH - much of what you and Ian have said here has gone straight over my head!:confused::confused::confused: - Family health issues have stopped me doing much with my workbee for the past few weeks so I haven't had a chance to play with any of this yet - hopefully it will start to make sense when I finally get to play with it. I got the impression that the buttons on the new DWC (for eg set XYZ) were hard-coded - if that's the case I would prefer to use macros.
    Alex.:D:D
  10. GeoffH
    GeoffH Journeyman
    Alex, sorry to hear that you are having a bad time at the moment.
    I think Ryan is implementing buttons like Set XYZ in js because they should never require changing and will not contain any hard-code, (Ian has removed the only hard-code (G54) in his modifications for multiple WCS).
    When you get around to installing DWC v1.0.7, I'm sure that you will agree that it's a great improvement for CNC Routers.
    - Geoff
    Mark Carew and Alex Chambers like this.
  11. Alex Chambers
    The screenshot certainly looks as though it will be much more suitable for cnc - good to see all the 3D printer stuff going from DWC.
  12. Ryan Lock
    Ryan Lock Veteran
    @Alex Chambers @GeoffH Yes i agree for experienced users having things hardcoded isn't ideal, but i do have to keep in mind new users that who buy our machines. I am thinking that i will keep the Set Work Zero buttons hard coded as i can't think of any reason why these would ever need to be different. But the Go To Work Zero to be a system setting file, not a macro. So still editable by the user, but not in the Macro folder. The reason being is that is linked directly to a button on DWC, so is a system file.
    I am working on at the moment switchable work coordinates directly in the interface :)
  13. GeoffH
    GeoffH Journeyman
    Yes Ryan, I agree with that.
    Regarding the work coordinate selection it looks like the Duet will support G54 to G59.3 which makes 9 in total.
    It would be neat to see the current WCS adjacent to the Work Coordinate display, eg a drop-down list
    But I might be too late ;)
    Geoff
    Alex Chambers likes this.
  14. Ryan Lock
    Ryan Lock Veteran
    Hi Geoff,
    Thanks for the info, i finished it off last night :). I just need to remove the hardcoding of Go To Work Zero now.
    Ryan
  15. GeoffH
    GeoffH Journeyman
    Hi to all JavaScript aficionados on this thread, I'm certainly not one but I've been pondering!o_O
    Duet Macros are useful but restricted to straight gcode text files with no embedded scripting language.
    Since the DWC is JavaScript based it occurred to me that it would be useful if an additional layer of js functions could be written that could be called from both the DWC (eg for probing) and from the executing Duet Gcode program? These functions / methods should be easily accessible to the user, not requiring to be built with the DWC, not to replace Macros but additional, to provide greater flexibility when needed.
    By way of an example, Post-Processing in Fusion 360 is JavaScript based which gives good control and flexibility, compared to the flat Configuration File used by Vectric for Post-Processing, which whilst being quick and easy to use, can be restrictive if you want to do something special.
    I'm not familiar with JavaScript Frameworks, so I wondered if anyone in this thread has had similar ponderings, and might know how to do it?
    Geoff
  16. Ryan Lock
    Ryan Lock Veteran
    @GeoffH Sounds like a unique idea i haven't heard from before. I am not a js expert, just about good enough to program the interface. It could potentially be possible i will have to ponder it some more :)
  17. GeoffH
    GeoffH Journeyman
    Hi Ryan, what I described is for the future, maybe best from the Duet people, if they are interested. Then merging your changes with a new DWC from Christian may be a challenge for GitHub?
    Keep up the good work! Geoff
    Ryan Lock likes this.
  18. GeoffH
    GeoffH Journeyman
    Hi Ryan, I noticed that Beta 3 has arrived, I will install that later, but I noticed that the Probing macros still have G10 P1 ... I believe the P1 should be removed to use the current WCS (from Ian here), also G54 should go. Geoff
  19. Ryan Lock
    Ryan Lock Veteran
    Yeah this one brings in Work Coordinate Selection. Integrating touch probe into the software is what i am working on now, so it will all be re-done on the next Beta and there will be no touch probe macros. Here is a sneak peak of the touch probe settings.
    ian McFadden and sharmstr like this.
  20. GeoffH
    GeoffH Journeyman
    Hi Ryan. Ok didn't know you were planning to remove your Z-probe macros. Geoff
  21. Alex Chambers
    Hi @GeoffH, @Ryan Lock, I'm guessing that if I install version 1.07 I'll have to change my limit switches to NC?
  22. GeoffH
    GeoffH Journeyman
    Hi Alex, no I didn't change to NC.
    That's assuming that you are using your own config.sys, because I can't remember if Ryan has gone to NC in 1.07?
    You will have to check your probing macros from what I remember, generally remove any G55 that you may have in any macro?
    You will have to change the G55 to G54 output in your Post-Processor for the first work offset, G54 is default, so it's not needed. The standard vectric post grbl(mm) doesn't output a work offset, so that's ok.
    Other than a much better DWC, the main idea in 1.07 is that the macros work with the currently selected work offset.
    You can make others current from the drop-down or entering G55 etc. at the Console. That said, I'm not using multiple offsets so I can't say how well that is working?
    Geoff
  23. Alex Chambers
    Thanks @GeoffH, are you using a probe? How does that work in the new DWC? I saw a screen shot that suggested that was different now. Hopefully that is still an editable file as I still want to use my message boxes to control jogging around fixtures if I can. Also are the homing files either macros or system files that can be edited?
    I'll probably have lots more questions when I install it - thanks for your support and forbearance.
  24. GeoffH
    GeoffH Journeyman
    Yes Alex, I'm using a probe, and I still use macros for that. I think Ryan is writing some js to do probing from a DWC pull-down, but you can still use macros if you want. I noticed that Duet may change to G38... for probing instead of M585 which isn't standard, so macros/js may need changing a bit when that happens. Homing is still using macros. Geoff
  25. Ryan Lock
    Ryan Lock Veteran
    Hey Guys, the probing macros will be replaced with GUI buttons in 1.0.7. Initially, the buttons will be not editable, only configurable via settings, but these settings should cover most configurations. In future i may add an option for advanced users to link their own macros to the GUI buttons, and override our defaults. The new buttons will work with NO and NC probes. In 1.07 you can select your WC, which ever one is selected is what the commands will run in. The homing isn't changing in 1.07
  26. Alex Chambers
    Will it still be possible to use a macro instead of your buttons? I use M291 message boxes to allow jogging in most of my macros.
    #56 Alex Chambers, Oct 14, 2019
  27. GeoffH
    GeoffH Journeyman
    Hi Alex, macros are implemented in the Duet control, the DWC has a GUI to manage and call them from the macros/system folders, I can't believe that this will be removed in 1.07, it isn't in Beta3.
    I think that Ryan is simplifying the DWC for new or basic WorkBee customers who are not interested in macro writing or modifying, but shouldn't restrict anything for more advanced users who may want to use macros for a variety of things including specialist probing - Geoff
  28. Alex Chambers
    Yes @GeoffH, I thought that would be the case. I would like to encourage Ryan to implement the ability to link user macros/system files to the DWC buttons he is working on though.
    Alex. :thumbsup:
    PS I noticed recently that even though they have changed to NC limit switches Ooznest's probing macros still use the Z endstop, which won't work with a NO probe - confuses new users.
    #58 Alex Chambers, Oct 15, 2019
  29. GeoffH
    GeoffH Journeyman
    Yes Alex, optionally calling macros from the buttons would be good, maybe specify the macro name in the appropriate settings form, or similar?
    Didn't know that NC was now used for WorkBee limit switches, yes that would seem to be a problem with a simple DIY touch probe using the Zendstop, I guess?? Maybe commercial probes will have NC/NO options I don't know or you could use one of the extruder endstops for probing? Geoff
  30. Alex Chambers
    Yes, the Duet has spare endstops, so you can use endstop 0 (E3 in the M585 line instead of E2) but I do think Ooznest are a bit lax on updating things.
