Drilling holes with the g-code generator (centering on what?)
Discussion in 'Control Software' started by Anselm Wiskott, Jul 6, 2022.
  1. Anselm Wiskott
    Hello,
    I am in the process of drilling a lot of holes into a plate. I design with ACad and I am using the Openbuilds g-code generator.
    When I center my holes using squares everything works fine. Yet when I center my holes using circles, the first hole is positioned correctly while all the others are located at <0;0>.
    I admit this might solely be a problem of mental agility on my part but centering holes on circles instead of squares makes my drawing easier.
    Any suggestion will be greatly appreciated.
    Greetings, Anselm
  3. Anselm Wiskott
    Thank you - will try
    Greetings-A
  4. Anselm Wiskott
    Works !
    Thanx for your guidance-A
