Dremel Finishing
Discussion in 'General Talk' started by Colin Mccourt, Apr 29, 2019.
  1. Colin Mccourt
    Colin Mccourt Journeyman
    How many folks are using a Dremel Multi-tool or similar for fine cleaning and polishing of cuts?
    What are the best accessories (part numbers) do you find that are invaluable for your work in finishing your projects.
    Regards
    C
    MaryD likes this.
    I do use those sanding drums but most often just a square of 80 or 120 grit sandpaper glued to a piece of insulation foam. This will very quickly smooth off any fuzzy edges and also removes tabs nicely.
    Colin Mccourt likes this.
  3. GrayUK
    It can be too easy to take off just that little too much sometimes. :banghead:
  4. Alex Chambers
    And a slightly unsteady hand (not enough/too much coffee - or other refreshment :D) can spell disaster! :ROFL::ROFL::ROFL:.
  5. Colin Mccourt
  6. jeffmorris
    jeffmorris Journeyman
    I use sandpaper and files to clean up the projects.
