Does open builds work with easel?
Discussion in 'General Talk' started by eric weatherman, Nov 16, 2019.
  1. eric weatherman
    Yesterday I imported a test file from easel and nearly at the end of the work piece I got this error.
  2. sharmstr
    Its an alarm state (i.e. limit switch triggered), not a G code error. Most likely cause is EMI.
  3. eric weatherman
    thank you. Do you know if the open builds controller has a place to input dimensions of the bit I am using? I used easel to design a work piece and entered the depth of the piece but my first attempt went too far. Any help would be great.
  4. sharmstr
    I'm guessing by the description you mean tool length. No it doesn't. But just go to Z0, then move up whatever distance you are off by, then zero Z again.
  5. eric weatherman
    Thank you!
