Different Routers
Discussion in 'CNC Mills/Routers' started by Ronald4418, Nov 17, 2020.
  1. Ronald4418
    Ronald4418 Well-Known
    Seeing as the Dewalt DW611 is darn near impossible to order anymore. Are others such as the DW616 an option using the Openbuilds Dewalt Spindle Mount? Or are there other examples that will fit the bill as most of the manufacturers don't list the diameters of their products?
    Yes! Checkout Router11 CNC Kit - WAY better than an Dewalt, proper ER11 precision collets, quieter, lower minimum RPM for machining plastics etc that the Dewalt just melts, proper NSK bearings, and many other advantages
    Comes with billet adapter sleeve to fit our router mounts included in the kit
    Also see
  4. Ronald4418
    I was hoping to find something that I could use 1/2" Bits.
  5. Ronald4418
    I'm in a hurry so I ordered theRouter11 CNC Kit.
    1/2" is quite a bit oversized for a hobby grade machine, what did you intend doing with it.
    Even our 1" diameter surfacing bit has a 1/4" shank: 3 Flute Surfacing Bit
    You can get ER11 collets from 0.020 up to 0.3125" / metric: 1-7mm
  7. Guillaume Rancourt
    Is the
    RoutER11 CNC Kit really better than the Dewalt 611??
    Aren't brushless motors much more reliable on the long run than the ones with brushes?
  8. sharmstr
    Yep. Its not as loud and Im getting way better floor and sidewall finishes.
    Giarc, Rhett E and Peter Van Der Walt like this.
  9. Guillaume Rancourt
    Ok but but isn't a brush motor less reliable and efficient on the long run than a Brushless one??
    I've tried many and killed many brush motor routers in the past 2 years.
  10. Ronald4418
    Sure they are, but I want to see someone purchase and install a Brushless Spindle for the same money as a Brushed Motor and its controller. I bought my Router11 when they were available individually and it was more than One Quarter the Cost of a Brushless Spindle and VFD.
  11. Guillaume Rancourt
    Yes you are right, I started with a brus motor and like I mentioned, I finally had to buy two that died before I bought my dewalt 611 that runs like a breaze though a little less quiet. I was just wondering. To me it is not a cost based question more the reliability question.
    Best regards
  12. Giarc
    My Makita is going on 5 years with no issue. I have Dewalt tools that get used and abused that are going on 17 years. It may have been the quality of your first two brushed routers.
