Design assistance needed please!
Discussion in 'CNC Lathes' started by selkov, Oct 3, 2020.
  1. selkov
    selkov New
    Almost ready to pull the trigger on my first build. Figured out what components are needed.
    But I am unclear about the electronics / software.
    My build will have 5 motors, two work in tandem.
    I suspect i need a lap top [i got this]:
    motion control board - will the Black box work?
    Power supply - should I do 12v or 24?
    I believe all 5 motors [for for sure] are standard nema 23.
    what software will allow me to program tapers over 40 inches or so?
    what software can I use to create pockets and inlays?
    Thanks for your support-
    Eds
  2. Giarc
    Software wise, I think Vcarve pro will make tapers over 40 inches if you are talking about a rotary axis for making long tapers. Vcarve desktop only allows up to 24". There is other software available, like Fusion 360.
    Is this a 4 axis machine? Why the 5 motors? If there is a 4th axis, GRBL does not support it so the Blackbox would not work.
    For a power supply, 24 Volts.
  3. selkov
    selkov New
    the build will have x/y/z and then the rotary axis. But the only way I could see to move the x axis [i think that's right] was to move the whole table so I need a motor on either end. I would rather do it with three motors but don't see how.
    x= in and out
    y= left to right
    z= up and down
    rotary head
  4. Rob Taylor
    Standard lathes have a single leadscrew on X (the cross slide). Not sure why you'd need two motors. Maybe if you post a diagram we could figure it out?
    Also, assuming it's a normal horizontal lathe, Z is left to right and Y is up and down. Z is always concentric with the spindle bore (except with machines like grinders). A standard manual machine lathe is an X-Z machine. Multi-axis CNC lathes with Y axes also typically have the Y-axis non-perpendicular to the X-axis to provide more clearance over the (slant) bed. Y then becomes an interpolated "virtual" axis. I don't know if you'd need to do this for your build, I doubt it, but worth knowing just in case.
    In either case, you'll need something more advanced than grbl to run 4 axes plus any additional IO like spindle brakes.
  5. selkov
    selkov New
    The only diagrams I have are hand drawn and i am a lousy artist.
    Is there some type of program or excel add on to simplify the drawings?
  6. selkov
    selkov New
    Best i can describe it is similar to the workbee 1050. However, the two side actuators will be 1500mm, the center table will be 1pc 1500mm Cbeam. The two top actuators will be 250mm. On the cbeam will be mounted a live center and a motorized 2 jaw chuck.
    This unit will be used for tapering of pool cue shafts as well as cutting pockets and inlays on pool cues.
    In the taper mode the motor on the chuck will simply spin. However when doing inlays it will need to move in fixed steps.
    Hope this is clear enough to understand why i was looking for 5 motors. I assumed that the two motors on the table could simply wire as one and move in tandem.
  7. Rob Taylor
    Gotcha. I think I can follow that easily enough. To include a Y axis, it may even make more sense for an extrusion build to run as a gantry machine. You're not gonna see much racking or other typical dual-drive issues with it being so narrow. The gantry will be X as normal, and Y and Z are flipped around (mostly important when it comes to CAM).
    Well, the Z motors would need a driver each due to variations in inductance, etc, but you'd split the STP/DIR/ENA signals from the controller to both, no problems there.
    The spindle is gonna have to run as a C axis for the pocketing since it has to have positioning, which might cause issues going back and forth between being a 3-axis dual-spindle XZY live-tool lathe and a 4-axis XYZA (in setup, not actuality for CAM purposes...Maybe) machine. Some kind of switchable spindle-speed-to-step-rate/step pulse passthrough breakout might be an option, so you have less to do in software... Because the software side of creating a true mill-turn appears to look like this: 4th axis as lathe spindle: question about index :eek: - it's complex, though skimming through the semi-working code on the second page it does look nice to just switch HAL pins around in software and not have to worry about anything.
    @phil from seattle, does grblHAL have sufficient abstraction to do something like this? Seems like it should if it's a true HAL on top of grbl. And it would be much easier/cheaper to do the other basic controller parts, in theory.
  8. selkov
    selkov New
    WOW> it like learning another language....
    What does "but you'd split the STP/DIR/ENA signals from the controller" mean?
    Having a hard time following the rest too...
  9. JustinTime
    JustinTime Veteran
    Step/Direction/Enable
  10. selkov
    selkov New
    Just a thought. If instead of using two complete actuators as the bottom slide could I use just 1 motor and a belt system to sync the actuators?
    Would this then allow me to run the blackbox motion control?"
    Also do i need the black box? Can I just use a breakout board?
  11. Rob Taylor
    The BlackBox is basically an Arduino Uno and four stepper drivers in a box. It doesn't gain you an axis, because grbl is inherently limited to 3 axes. Two of the drivers are wired together internally as I described above.
    If you can figure out how to do an X-Z-C only build, you could use a grbl controller, but if you have to have a Y axis to put flats in, it's not a viable option. I think you can get away without treating the "lathe spindle" as a spindle, just run the whole thing continuously as a standard XYZA 4-axis mill. The lathe part of this is confusing things more than it needs to, and with only live tooling and no static lathe tooling, there's really no advantage to thinking of it as a lathe. Think of it as a mill with a rotary axis.
    Not sure what you mean by "a breakout board". Depending on what you need, a really basic CNC control system is a g-code interpreter/GUI, a planner/stepgen, and the drivers that power the motors. For grbl, the first part happens on the PC, the second part on the Arduino/ATMega chip, and the third in the drivers- whether they're standalone boxes or all together on a board like inside the BlackBox.
    You need a more advanced controller, which is going to be more complex to install, configure and run. I use LinuxCNC, which can do up to 9 axes, but it's not easy.
    Alternatively, consider swapping between your Y and A axis motors in a single driver on different programs, and only run three axes at a time. I'm slowly convincing @Batcrave to do this with his half-a-LEAD, it's definitely a viable option and allows for the use of grbl.
    To do it as you originally envisioned is a much bigger project than you realise, I think. The mechanics is easy. The electronics definitely isn't!
  12. selkov
    selkov New
  13. Rob Taylor
    I was referring to this:
    Don't worry about the spinning, just keep it in "indexing mode" (which can also do continuous motion, of course). Let the program do the work.
    grbl is a controller that runs on an Arduino. It's 8 bit, so not super accurate, but good enough. Simple, easy to work with, quick to get up and running, well-documented. You just send it g-code with a computer. It's limited to 3 axes though, and doesn't deal with rotary motion very well. Doesn't accept very many g-codes either, because it's almost at the limit of the hardware.
    Mach 3 and LinuxCNC are both PC-based controllers. Mach 3 is usually used with a SmoothStepper for high-quality motion, where Mach 3 just does the planning and the SmoothStepper actually does the stepgen. It's an expensive way to go and doesn't seem to be all that effective, to me? I've heard not-so-good things about its support and general capabilities, tbh. LinuxCNC does everything and can output signals to stepper drivers through a parallel port (to a C25 5-axis breakout, say). Again, you get higher performance with more expensive hardware, but it can be inexpensive.
    No idea what microstep is.
    bharath likes this.
  14. phil from seattle
    phil from seattle Journeyman
    Yes, grblHAL has the ability to control up to 6 Axes. It is also easy to gang axes together.
    I know a basic lathe isn't what's wanted but there is at least one lathe (Emco conversion) being run by grblHAL. Here's the Hackaday posting of it. Doesn't say grblHAL but it is most definitely running it. There is a video of it cutting threads - I've been drooling over that. Pretty cool stuff. I am working on a showcase of grblHAL machines and the lathe will be in it.
    If I understand correctly one of the axes will rotationally position the workpiece for cutting. This is pretty much standard "4th axis" stuff. Any 4 axis machine should be able to handle it. I think this is essentially a moving gantry machine (ganged motors for that) and a motor for rotational axis. n'est ce pas? 5 motors are thus needed. You will want to get a motor with fairly high torque for the 4th axis. This Old Tony did a similar sort of thing and had some interesting observations.
    My Teensy 4.1 breakout board is set up for 5 Axes. You can read about it here. You would gang Y and B together and run A as the rotational axis. Pretty easy to do.
    And, when is a grblHAL version of the BlackBox coming? :)
    [edit] one other thing, if your gantry is moving (vs a moving bed), you definitely want two motors to drive the gantry. The bearings on the rails for a moving gantry simply can't be tight enough to prevent racking. You will be MUCH happier with a motor on each side.
    #14 phil from seattle, Oct 6, 2020
    Giarc likes this.
  15. Giarc
    So, could I then use this for a K40 conversion so I can have an adjustable Z table and a rotary axis? Please say yes! :nailbite::nailbite:
    I do not want to have to fork over $200+ for an alternative board and wall wart power supply that comes with it. I know I can use regular grbl but I hate to have to redo settings every time I unplug the y axis and plug it into the rotary.
    #15 Giarc, Oct 6, 2020
  16. phil from seattle
    I assume you mean using steppers to control the table height? I don't see why not. You would use the sender or a pendant to control Z.
    This is what I think you are asking - X and Y motors for mirror positioning, Z (maybe ganged to B for 2 motors) to control bed height and A to drive the rotary axis. Totally doable with grblHAL. Though, I don't know how you generate the GCode - would like to learn about about that. Cost of the controller is about $60 - BoB, Teensy 4.1 and connectors. grblHAL is free. The new sender (currently Grbl GCode Sender but soon to be renamed to IoSender) is really well done. If you liked Grbl Panel, you will love IoSender.
  17. Giarc
    Therein lies my problem. :)
  18. Rob Taylor
    Would probably have to do it the way I used to do it before I started using LaserWeb more- use Fusion 360's 4th/3+1 milling features, then manually modify/custom-post-process them to laser code (mostly modifying Z-5s to M4s, etc). It's a bit of work with Notepad++, but once you've done it a couple of times it'd be pretty easy to algorithmize the process.
    My laser already has a Z axis and that's never been an issue. A axis might be another matter.
  19. phil from seattle
    Then I would use A as a bed height motor and Z for the rotary axis. It doesn't matter which axis for bed height since it is manual.
  20. phil from seattle
  21. terjeio
    terjeio Well-Known
    Perhaps a bit OT but since VCarve and K40 lasers has been mentioned above:
    Laser PPI mode and tube coolant handling plugins now under development for grblHAL.
    ioSender has support for Vectric Output direct to machine for those who do not want to fiddle with saving and loading of .nc-files.
  22. Rob Taylor
    :eek: You must be
    Welcome!
  23. phil from seattle
    Nothing slips by you Rob! Yes, Terje is da man. You can see several of his projects in the showcase. Amazing work.
  24. Rob Taylor
    Haha, I was like hmmm, I recognise that name from somewhere.... :D
    And fwiw, @terjeio, I'd like to see this little discussion thread that Phil started updated and added to by someone who knows the system inside out: CBeam and a Workbee using grblHAL - while it may not be ready to replace my LinuxCNC controls or run any random machine I throw it at, I'm thoroughly intrigued by the idea of a 5-axis, 32-bit control running on hardware the size of a quarter (man, living in the future can be cool)!
