Delta-Six
Discussion in '3D printers' started by Sage, Jan 26, 2014.
  1. David Bunch
    David Bunch Veteran
    You might be interested in taking a look at putting a tetrahedron on the top to make a taller delta more stable. I have not thoroughly tested this idea, but seems like tying the 3 columns together at the top should make it more stable. Here is my parametric design for that on thingiverse: Parametric Tetrahedron Top for Delta 3D Printer by GeoDave
  2. Bruno M. Silva
    Certainly looks neat :)
  3. Justin Edwards
    The biggest benefit from orientation probably comes from the wheel mount width, the narrower the wheels mount the more error in torsional deflection, which can be a real thing with high acceleration moves.
  4. David Bunch
    David Bunch Veteran
    Is there some optimum width between the pairs of Delta Arms or should it be based on the width of the wheel spacing? I have not seen where anyone has mentioned this. I was checking some dimenions on mag effectors on thingiverse & saw dimensions of 46,50,54 & one that was over 70mm between the centerlines of the pair of rods. Looks like the Traxxus carriage I was starting with was about 60mm. I am planning to design an effector and carriage to use with these parts I bought. Thought I might thread a steel M4 bolt on the opposite side of rounded disc magnets to keep the magnet in place by pulling it towards the steel bolt.
    Here are the magnets & threaded steel balls I purchased. I thought this was a very good price for $7.50 for the magnets & the steel balls.
    18pcs N52 Strong Round Magnets D12x5mm Rare Earth Neodymium Magnet with 4mm Hole
    16Pcs Φ10 M4 Threaded Steel Ball Rod Ends For Kossel 3D Printer Magnetic Joints
    SleekGrid likes this.
  5. AusCrash
    AusCrash New
    I'm in process of building a delta with strong influences from this delta-six design and I'm going to use the exact magnets & balls you linked to. My own crude testing has showed the ball/magnet combo holds slightly more than 600gms of weight before separating.. I'm hoping this is strong enough but time will tell.
    I had a similar question regarding arm spacing the theory out there is as wider is better, with limit being effector size. My plan is to run 70mm between centrelines. Here is some discussion (hopefully posting this link is ok?) about it Optimum Arm Spacing
  6. David Bunch
    David Bunch Veteran
    Thanks for that link. That should be very helpful. I am using 2060 aluminum, so I should be able use wider arms. I will have to start looking at effector design to see what width I want them.
  7. Justin Edwards
    I've tested the joints on my experimental effector design at about 60lbs load per joint and the plastic printed part holds up without any issues, not the slightest movement and the bearing still moves freely. I'm planning on widening it up a bit more still. The joints are 90 cents and weigh 12 grams, and have a static load rating of about 1000 lbs.
    I printed my own misalignment spacers to allow huge angular freedom. [​IMG]
    Here's a little video demo without the spacers on both sides https://goo.gl/photos/WTuL6jXkk7HP7GH56
    And here's an STL of how it is currently 3dModeling/MegaFector.stl at master · justinledwards/3dModeling · GitHub
  8. Justin Edwards
    Also here's a design I ended up not wanting to go with because the aluminum rod bent much more easily than I had thought it would. [​IMG]
  9. David Bunch
    David Bunch Veteran
    What type of plastic are you using? I am using PETG.
  10. Justin Edwards
    I use PLA, impact resistant PLA, and PETG
  11. lmclaren
    lmclaren New
  12. Justin Edwards
  13. LoganJ13
    LoganJ13 New
    Very interesting concept. My one concern is that the extra direct of motion allowed by those joints could possibly allow the print head to wobble?
  14. Justin Edwards
    That shouldn't be allowed to happen as long as your rod lengths are all identical forcing the joints to be parallel. That's why it's pretty important to use a single solid jig to make all of the rods.
  15. lmclaren
    lmclaren New
    @Justin Edwards
    Thanks for the reply, I did not know about Onshape, I have just spend the last few days using it to design a new effector for my printer.
  16. Mopar32985
    Mopar32985 Well-Known
    so i built the ob13 and the ox cnc off this site. I just started printing parts for this today cant wait to get started on it. just using the files in the zip. Anyone reccomend different files besides the ones in the zip file.
  17. SleekGrid
    SleekGrid New
    hi...im new here....
    im planning to build Delta 3D printer and i already have 4 unit 1500mm v-slot...my dimension is 1500mm vertical & 500mm horizontal....can anybody calculate for me the best arm lenght refer to my dimension?
    want to use magnetic ball to hold effector.....what is the latest stl file all component to build this monster?
    Best Regards
    SleekGrid Syndicate
  18. lmclaren
    lmclaren New
    Back further in this thread there was mention of calculators for the arm length.
    I used the calculator to get close and then some coathanger wire cut to length to simulate the arms to check how looked. maybe balsa wood from a hobby shop?
    Wild guess is around 450mm.
  19. lmclaren
    lmclaren New
    btw, Sleekgrid,
    My machine is in the ball park of what you are building, because my machine is oversize from the original design, I have had problems with shaking at high speed. I ended up bracing diagonally on each side and it is now solid as a rock.
    With the benefit of hind site, (the next revision) I will make the top and bottom sections box sections, eg double up the verticies and horizontal assemblies at the top and bottom, space them say 200mm vertical and then bolt aluminium plate around the outside. At the least it will give you some where to hide the electronics
  20. SleekGrid
    SleekGrid New
    Ok Imclaren...i'll try it first :)
  21. SleekGrid
    SleekGrid New
    Imclaren...can you show me your setup?
    maybe anybody here can show up their Delta 3D Printer with pict using this simple spec :
    PROJECT NAME :
    VERTICAL LENGHT : (MM)
    HORIZONTAL LENGHT :
    ARM LENGHT :
    MATERIAL : 2020, 2040, 2060
    PRINT AREA SIZE :
    MOTOR TYPE :
    PULLEY : _____ (TOOTH) BORE SIZE :
    BELT SIZE :
    HOTEND :
    CONTROLLER BOARD :
    ADDON ITEMS : AUTO LEVELING, ETC
    So all newbies can make reference...tq
    Best Regards,
    SleekGrid Syndicate
  22. Robert Hummel
    Robert Hummel Custom Builder
    It's bin a while but I'm still working away in the background on a few things.
    I'm not sure how many have a completed build yet but here is where I am on my delta
    I will post the files once I get to my PC
    Finished the custom heat bed last night and all that's left is the wiring
  23. Kyo
    Kyo Veteran
    Your build is looking great :thumbsup:
  24. Robert Hummel
    Thanks Kyo :)
    Here are my files, I made printable versions of the alumi parts but suggest getting your hands on milled versions.
  25. Mopar32985
    Thanks man firing up the printer now! Will also see what aluminum i have laying around i think all i have is 1/8"
  26. Robert Hummel
    That's all you need for the carriage and belt plates the effector plate is 1/4
    SleekGrid and Mopar32985 like this.
  27. SleekGrid
    SleekGrid New
    Awesome...!! Robert Hummel....
  28. tim3802
    tim3802 New
    Robert Hummel I sent you a pm
  29. Robert Hummel
    reply sent :)
  30. jerry426
    jerry426 New
    I'm starting a build based on this Delta-Six design. My other build (barely started) is the C-Bot. I decided to do the delta first because I already have the extrusions for it in approximately the correct length.
    After reading through this discussion, I decided to double up on the vertex assemblies for more rigidity. I will add diagonal bracing later if needed to reduce twisting of the frame. I re-modeled the vertexes in SolidWorks so I can eventually model the entire thing using the tool I am by far most proficient with.
    Horizontals are 450mm and Verticals are 1200mm. Both dimensions subject to change based on more research I've yet to complete.
    This is my first delta of any kind. I should be able to print all my parts in ABS given my current printing situation - however I am considering PETG as well.
    Does anyone see any general problems with my plan, or with my remodeling of the vertexes?
