Dc Ground to AC Earth short (Arduino with no name 2-wire probe)
Discussion in 'General Talk' started by DELMAS, Dec 16, 2023.
  1. DELMAS
    DELMAS New
    Hi Alain,
    Today I have been the same problem than you, Alarm 4 & Error 9 with the Probe.
    After 2 hours of trouble, I solved the problem by reversing the 2 wires on the probe.
    Black instead of red and red instead of black.
    And now no alarm et no error, and the probe process is OK.
    Hope this helps
    A+
    Robert
  2. Alex Chambers
    That masks the problem rather than solving it. If you have a connection between mains EARTH and DC GROUND you have a potentially dangerous fault. Please read the whole thread, especially the posts from @Peter Van Der Walt.
    Alain JBT likes this.
  3. DELMAS
    DELMAS New
    OK, thank Alex for your comment.
    I will search...
    Robert
  4. DELMAS
    DELMAS New
    Hello Alex,
    My language is French, I hope my English is clear enough.
    I investigated with my multimeter.
    I don't have any electrical shorts between GND (DC) and EARTH (AC).
    But by mistake I had connected GND (DC) to the chassis of my DYI CNC.
    And as I hadn't connected EARTH (AC) to the chassis, I didn't have an electrical short.
    I removed this electrical connection (GND (DC) <--> CNC chassis).
    But I have to make the EARTH (AC) connection to the CNC chassis to be safe.
    My CNC controller is Arduino UNO + CNC Shield 3.0, in this configuration the probe works only if the plate is connected to the signal and the magnet/clamp to the ground.
    If I reverse these connections, the probe doesn't work.
    I have found on several forums that the probe works only in this connection configuration with Arduino UNO + CNC Shield 3.0.
    Please note that this isn't the OpenBuilds probe, but a probe without the LEDs.
    If you have any comments, please don't hesitate.
    Here's where I am for the moment.
    A+
    Robert
  5. Christian James
    Christian James Journeyman
    If the probe does not work in the proper configuration {magnet to signal and plate to ground}, then the shield circuitry is maybe where the problem lies. I assume the shield you have is a 4988 driver board {3D printer}?
    I don't know what the your shield circuitry is like but the probe base wire must go to Arduino ground pin, and the magnet/clip wire to Arduino pin A5. You should also fit a 10k resistor between the probe clip connection {A5} and the 5v pin on the Arduino..
    #5 Christian James, Dec 21, 2023
  6. Giarc
    Also, the grbl 3.0 boards have been obsolete for a long time and the z probe pinout is different than what grbl 1.1 uses. I really wish certain companies would quit selling that board and claiming it is grbl compatible. They should at least point out that you have to use a really old version, or that you need to swap a couple pins. Connecting Grbl
