Cutting issue using aspire
Discussion in 'CAD' started by mIRCnC, Dec 19, 2021.
  1. mIRCnC
    mIRCnC New
    Here's my thing to "cut" the cross-sections are a pocket of 2mm. however, when it's cutting around the whole piece and the pocket, it's not removing everything..
    Except drawing a new design with a prolongation of the cross-section, is there any trick to do in Aspire to have a pocket and the cut (around the whole piece) to be clean? (see red mark on picture)
    Thank you! :)
  2. Giarc
    If I understand correctly, it is failing to cut a small amount at each end of the pockets? If you are trying to cut each as individual pockets, you need to extend the pocketing vectors at least 1/2 the diameter of the end mill. Because it is a round tool it is impossible for it to remove all material unless it cuts beyond the pocket by 1/2 the diameter.
    I do not know of any trick other than making the whole thing one pocket. But if they are different depths, that won't work. So joining them all as one vector should be quick if they are all the same depth.
    mIRCnC likes this.
  3. mIRCnC
    mIRCnC New
    exactly,
    I'll try extending! :)
    Thanks, I was wondering if there was any trick to bypass this =)
  4. Giarc
    How do you like Aspire? I was thinking of upgrading. I am curious how user friendly it is for creating 3D files of my own.
  5. mIRCnC
    mIRCnC New
    to be honest, I'm new to aspire, I'm not sure I could comment well enough but the vector thing is a pita... Just extending the pocket is 4%)($/%)!/$%, I guess I don't understand the soft good enough yet :p
    Giarc likes this.
  6. mIRCnC
    mIRCnC New
    lol
    10 sec later, found how it worked... I was using sketchup before... so a lot of thing is different ;)
  7. mIRCnC
    mIRCnC New
    Which soft are you currently using?
  8. Giarc
    I have Vcarve desktop for carving 3D models. For making flat objects I use Fusion 360.
