Cutting file format created and saved in VCarve?
Discussion in 'CNC Mills/Routers' started by Johan van der Walt, Jun 13, 2024.
  1. Johan van der Walt
    Hi,
    I can't get the cutting file to run on Openbuilds. The message tells me there is a letter missing on the G code line. What is the correct file extension to save it so that Openbuilds will open it correctly?
    If that is the problem?
    the file name and extension do not matter at all, Gcvode is just plain text.
    What matters is the postprocessor, you must use the openbuilds one for vcarve so it produces gcode that is correct for GRBL controllers.
    docs:software:vectric [OpenBuilds Documentation]
  3. Johan van der Walt
    Attached is a portion listed on Vcarve's postprocessor. No GRBL or Openbuilds listed.
  4. Johan van der Walt
    Could it be that my Vcarve version is to old? Purchased in 2012.
  5. Johan van der Walt
    I will do some updates on Vcarve, should solve the problem.
  6. Alex Chambers
  7. Johan van der Walt
  8. Johan van der Walt
    I extracted the files to the sub folder, PostP of Vcarve but gives me this when I open the program.
  9. Alex Chambers
    So, V carve pro V6.5?
    (Program Updates〡Vectric)
    That may not help you though as it looks though you will need a grbl post processor - before my time in cnc, but I believe grbl dates from 2014?
    Options are, ask Vectric for help, upgrade your Vectric software .
    VCarve Pro v12
    #9 Alex Chambers, Jun 13, 2024
  10. Johan van der Walt
    Thanx Alex, will do.
  11. Johan van der Walt
    I am currently looking at Carbide V6. Will this program save G-code that will be recognised by Openbuilds as a cutting file?
    My current Vcarve is out of date and to expensive to buy the new version.
  12. Peter Van Der Walt
    We are a Company actually, so you might refer to OpenBuildsCONTROL (or just CONTROL) instead? CONTROL doesn't matter. We don't do anything except send the file along... To a Grbl compatible controller
    Looks for GRBL compatible CAMs: docs:software:overview [OpenBuilds Documentation] - if in doubt ask the CAM vendor whether they are 100% grbl / grblHAL compatible
  13. Johan van der Walt
    Thank you Peter. I will have a look at the link.
  14. Johan van der Walt
    Good Morning,
    I used Openbuilds CAM software as suggested by the members and it created a cutting file from my dxf drawing.
    Problem:
    1. Set it to cut 6mm deep (total). Only cut 3mm deep. I am not sure what I did wrong?
    2. After trying different settings we reloaded the file on the controller software. The router still cuts to the settings from the first file loaded. Is there a way that I can cancel or reset the previous file settings on the controller?
  15. Peter Van Der Walt
    Does the machine jog the correct distance? (Jog 20mm did it move 20mm?) if not, Wizards and tools > Calibration Menu
    Must have picked the wrong file or forgot to export the changed file :) It runs whatever you give it.
  16. Johan van der Walt
    Thanx Peter I will go back and check the calibration. My question 2 seems to be a mystery. We saved file to different settings, export them (I remembered) but still cutting first file settings. I will go and try again, slowly step by step. My friend bought this machine and because he is only half computer literate (I am the other half;)) we are trying to work it out together. I have a MechMate at home (cutting for 12 years). No problems like this, with easy software.:) I must sell my machine because I am retiring to a much smaller house.
  17. Peter Van Der Walt
    What 'settings' changed?
  18. Johan van der Walt
    Our first file cut to the depth & feed rate that we saved. We edit the file increasing the feed rate and double the depth. Saved the file under a different name, export it and open it in the controller. We tried a few more but the machine was stuck on the first file settings. Nothing changed.
  19. Peter Van Der Walt
    Oh I thought you meant settings. That I'd rather refer to as "toolpath parameters" - to avoid the confusion with settings
    Run me through how you do it exactly, using same file name or different. Which controller (CONTROL, Interface or 3rd party). Screenshots etc
