Custom Ox Mods
Discussion in 'CNC Mills/Routers' started by DazTheGas, May 9, 2015.
  1. Traxxtar
    Traxxtar New
    @daz
    I'd like to see more info about your proximity sensors, what kind, and how you have them connected and 'talking' to the system.
    Thanks!
  2. ooze76
    ooze76 New
    @daz
    The cable management and enclosure set-up videos are great.
    Is there any chance of putting together a part/supply list, particularly for the VFD, and drawings for your baseboard?
    Any help would be greatly appreciated.
    I nearly forgot to mention, thanks for the detailed videos on Mach 3 operation.
    As I am new to the process of getting the "In my head phase" to the "Look what I made phase", thank you.
  3. apburner
    apburner New
    Love that first video and I don't see what was wrong with it. A beautiful build. I did have a funny moment during the watching though. Who besides me when the vinyl cutter started heard the beginning rift to Teenage wasteland by the who. Maybe it was just be.
  4. DazTheGas
    DazTheGas Journeyman
    Time to Beef Up the Ox
    DazTheGas
    Scott Watson, Gaou² and Ronald4418 like this.
  5. Lars Carlsson
  6. DazTheGas
    I use Mach4 so the post processor I`m using is actually a customized mach3 post processor, if you are using GRBL then just a Generic post processor should be fine
    DazTheGas
  7. Giarc
    Beautiful. I am curious what bit and what feed rate/depth of cut/step over you used. I too have a lead screw driven Ox variant, so I am always curious about these things. I have cut some aluminum successfully, but I mostly cut wood.
  8. DazTheGas
    I am using Zeda Carbide bits (Very good they are) and tend to keep things simple, at an average a 3mm bit I would run spindle at 12000 rpm , Feed rate 1000mm/min at 0.3mm depth, any stepovers I normally do at 2/3 of the bit size and I seem to get constant results. :)
    Funny but they sell bits for aluminium that are dearer than standard ones but are crap, I am using the Tialn XI range.
    DazTheGas
  9. Giarc
    Thank you!
  10. Ronald4418
    Ronald4418 Well-Known
    Giarc provided me with a link to your video after I was discussing belt slippage on my Y-axis after I described adding a single leadscrew to my longer X-Axis. I think you may have just solved all of my issues with slippage with your design. It would be nice though if you provided a drawing of your cross axis modification. I'm quite sure there are many others who could greatly benefit from your design ideas.
    Gaou² likes this.
  11. Ronald4418
    Thanks Giarc, your knowledge on this issue has just solved all of my issues.
  12. DazTheGas
    Ox Upgrade Kit ;-)
    DazTheGas
    Giarc likes this.
  13. John strong
    What spindle are you using?
  14. John strong
    I would like to build an ox similar to yours.
  15. DazTheGas
    Its a 1.5kw air cooled spindle with an ER16 collet and takes bits upto 12mm, just purchased the water cooled version for new machine.
    DazTheGas
  16. GrayUK
    DazTheGas.
    Are you sourcing your spindles through one supplier, or are you shopping around?
    The reason I ask is that I intend to get myself a 1.5kw water cooled spindle, but I am always worried I might pick the one unreliable supplier. :banghead:
    So, if you have had great service from a company, particularly in China, I would be greatful for a name or site to visit. :)
    Gray
  17. DazTheGas
    I shopped around for both spindles as the 1.5kw normally come with er11 collets but the ones with er16 collets are much harder to find. The latest one I had to get from germany as none in the uk.
    DazTheGas
    GrayUK likes this.
  18. John strong
  19. Gary Bonard
    has anyone tried drilling with a chines water cooled spindle. Isn't the high rpm a problem?
  20. DazTheGas
    Well it had to be done, just need the space for my new machine Spartacus so this is the final Ox Mods video.
    Thanks for everyones support over the years, its amaizing that the first ox mods was april 2015 so the ox has given me 2 1/2 years of service actually come to think of it so has the ESS and still going strong.
    DazTheGas
  21. muzzlitebeer
    Sorry if this is a dumb question. (I'm new here) Where are the files for the plates you made to convert it from belt to screw? It's exactly what I want to do to the Ox I intend to make in the next few months.
    Great video of the conversion.
  22. DazTheGas
  23. Scott Watson
    Dazthegas I was wondering if you have the files files for the plates required to upgrade to lead screws. I found it for solidsworks and such but was wondering if anyone has them for Sketch up. Any help would be greatly appreciated.
  24. DazTheGas
    Unfortunately I dont, I have never got on with sketchup and have recently started using fusion360
    DazTheGas
  25. Scott Watson
    Ok Thanks anyways, I’ll just try to have the files converted to a sketch up format. I am very much looking forward to having my ox converted over to acme screws for better accuracy and no belt jumping.
  26. Mark E. Crum
    Hi Scott, did you get the files to convert to Sketchup? If so can you share them please?
  27. Mark E. Crum
    I have also been trying 360... Do you have the files for that format? Funny, I was thinking of the exact same modification as I build the OX Metal..... But was not sure how I would do the X axis. Brilliant!
