Custom Acro Size ?
Discussion in 'General Talk' started by coxsox, Jun 9, 2024.
  1. coxsox
    coxsox New
    Looking to purchase my second Acro system, but would like a specific size due to space limitations. I need a work area of 800 * 600mm. I suspect this is possibly, but a forum search doesnt see to find a similar question.
    I'm guessing it something like cut the frame to the correct size, modify some size settings somewhere and thats about it ?
    Yes, and if you work out the lengths the shop will generally cut them for you. Just leave a note in the comment section when you order it.
  3. coxsox
    coxsox New
    Thank you. Does the price change, which model should I select ?
  4. Rick 2.0
    OpenBuilds ACRO 1010 40" x 40" - OpenBuilds Part Store should do the trick for you. Work area is 800 x 800 so you'd really only need to trim down one axis to get 800 x 600. As for which axis that's going to depend on preference. Trimming it shouldn't affect the price.
  5. coxsox
    coxsox New
    thanks I may just stick with the 40" x 40".
    If I want to add a drag chain to the X axis, do I need to specify longer cables for the X axis motor on the machine order, and if so how ?
    Also what size drag chain for the 40" machine ?
    thanks
    #5 coxsox, Jun 10, 2024
  6. Rick 2.0
    The wires should be long enough as they typically come in a stock length which you have to cut down. Something to verify with the shop though.
    As far as adding a drag chain, you would need to go with a 1000mm chain but mounting it becomes an issue. You will need to add an additional rail parallel to the x-axis for it to run on. A single stick of V-Slot 20x20 Linear Rail Aluminum Extrusion Profile (openbuildspartstore.com) with a length matching the x-axis rail and a couple of 3 Hole Joining Strip Plate - OpenBuilds Part Store to serve as outriggers off the main rail to support it. You will also need a package of Tee Nuts - M5 Pack - OpenBuilds Part Store and Low Profile Screws M5 (10 Pack) - OpenBuilds Part Store to attach it.
    Giarc likes this.
