Creating Text in bCNC
Discussion in 'General Talk' started by Doug Corwin, Mar 29, 2019.
  1. Doug Corwin
    Is there a Text plugin in bCNC and if so how do I get to it?
  2. sharmstr
  3. Doug Corwin
    I've been looking at the vlachoudis site and I'm still confused, I found the 'Text' information in the user file but I can'y figure out where it is in the buttons at the top of bCNC. Thanks for your help.
  4. sharmstr
    I dont use bCNC, I was trying to point you in the right direction.
    If you can't figure it out, why not give Openbuilds CAM a spin. It has text built in and its easy to use (in my limited experience): OpenBuilds CAM Gcode Creator - Public Beta You can save the gcode file, then use bcnc to run it. ...or, use Openbuilds Control :)
    MFCarew and Giarc like this.
  5. David the swarfer
    in bCNC click Tools
    then you see a bunch iof icons like Cut,Profile,Pocket,Drill,Tabs and so on.
    at the bottom of that toolbar is a grey tab labelled CAM with a little triangle next to it.
    click that CAM word
    Now you see a menu, and Text is on the Generator submenu
