Crazy idea about Igus and Everman Belt System
Discussion in 'Concepts and Ideas' started by wojak, Mar 31, 2019.
  1. wojak
    wojak New
    Hello, I am working on my super long CNC and trying to utilise Igus linear sliders with Everman Belt System.
    So there is the concept: A360
    Do you think it will work? Does everman need four wheels or two wheel will be enough?
    Four is obviously better but two should work. One thing you need to keep in mind is that you will need vertical slotted holes on the motor mount to be able to pull the pulley tight into the loop created.
    Additional discussion on this idea can be found here including an interesting tank track concept.
    MaryD and wojak like this.
