Controller recommendation for C-Beam XL
Discussion in 'Controller Boards' started by gdenicolas, Sep 23, 2019.
  1. gdenicolas
    I built my C-Beam XL with a Novusun NVUM 4 Axis, but I only could use it with a Windows XP Laptop and Mach 3 software.
    What do you recommend me to be able to use Openbuilds Control Software?
  4. gdenicolas
    Maybe I made a mistake, but I removed the motor drivers (Stepperonline DM542T), and connect the NEMA23 motors directly to Openbuilds Blackbox.
    I have burned two Openbuilds Blackboxes.
    Should I reconnect the motor drivers, and then those to the Openbuilds Blackbox?
  5. Rick 2.0
    What power supply are you using?
  6. gdenicolas
    I am using
    500W 36V 14A 115/230V Switching Power Supply Stepper Motor CNC Router Kits
  7. Giarc
    The Blackbox is a 24V system which may be why you burned them up if you used a 36V power supply. If you look where you connect the power supply to the Blackbox, the inputs are labeled GND and 24V.
  8. gdenicolas
    Thanks!!!
    Now it's working great!
  9. gdenicolas
    I connect a 24V power supply, a new Blackbox, and a new Interface.
    When I try to update the Interface firmware (I am connected to wifi), receive error "0x02" (picture attached).
    When I try to update the firmware via USB drive, the USB drive is not detected by Interface.
    Update to v1.52 to using method 2 or 3 (see the firmware update section of docs.openbuilds.com/interface) - older builds of the Firmware does not know about some server side changes. Do an offline update first - the newer firmware knows how to talk to the new update servers.
    Please contact the store about the USB issue, by creating a new ticket on Support
