Control Software With CNC XPRO V2 issue
Discussion in 'Control Software' started by vortexblue, Apr 5, 2022.
  1. vortexblue
    Hi,
    I purchased a CNC xPRO Controller V2 a looong time ago. The machine (belt driven 1500x1000 router) was to be used for a project that got sidelined. I''m trying to get my machine back up and running again.
    I've downloaded Openbuilds control software (where I purchased all my machine parts) and it says I need GRBL 1.1. I think I'm on 0.8?
    I followed the directions at this link: How to Reflash GRBL to the CNC xPRO
    Everything has seemed to work well. Openbuilds can see and connect to the controller. If I press on the buttons (pause/abort/etc), they send commands that I can see in Openbuilds Control.
    If I try and jog the machine, I get no movement at all. Also, the motors don't feel 'energized' - I can move them by hand.
    What have I missed?
    Thanks for any help.
    Chris
    Did you remember to set $4 to the correct value for your xPro. Some needs it as =1 (Enabled) and some older ones were =0 (Disabled)
    Play with both options in the Grbl Settings tab
  3. vortexblue
    Ok,
    $4 was disabled, I toggled it on / reset grbl / retried to jog. No luck. Tried the same with $5 while I was there.
    Under Troubleshooting, I am able to see the button pushes - the 2 devices are definitely communicating.
    For a Grbl based controller to move the motors it only needs:
    • Correct $4 setting
    • Power applied (check psu)
    • Motors wired correctly (incorrectly wired motors shudder in place, if nothing happens that is not it)
  5. vortexblue
    Ok, thanks for the suggestions.
    I've got $4enabled,
    Power supply is working, fuse to xpro intact, fan is running, power switch on, it's receiving and sending messages
    Motor wires have not been moved/altered since it last ran in 2017. There is no shuddering or resistance to the motors. I can move them by hand easily. Visual inspection has them looking like they're connected well.
    The GRBL I uploaded to the xPro is 1.1H. Perhaps the older hardware doesn't like this particular flavor?
    ________________
    EDIT:
    There was a sketchy connection to the power switch. We're running, but it sounds really cranky and is throwing alerts.
    Good enough to move onto the next issue! Thanks for your help!
    #5 vortexblue, Apr 6, 2022
    Try disabled too. The newer V3s (there was a mid-v3 change at some point) and the V4s definately had $4=1 (Enabled) but some of the older boards (like your V2) used $4=0 (Disabled) (see their notes next to $4 in the examples on 5. Troubleshooting · Spark-Concepts/xPRO Wiki)
    No difference in regards to moving motors, but do be aware of 2. Connecting CNC xPRO · Spark-Concepts/xPRO Wiki (Not relevant to current issue though)
    Remember to set $1=255 too - see last sentence of Grbl v1.1 Configuration · gnea/grbl Wiki
  7. vortexblue
    Ah!
    I ninja edited the previous response when I found the flaky connection. I didn't know you were already on it.
    Thanks again.
    Reverted your edit as an addition just to clear things up for others referring to this thread in future :)
    Sweet, glad you found it. Falls under that earlier :)
    vortexblue likes this.
