Composite Cutting Tips // TACIT RONIN II Build Preview
Discussion in 'General Talk' started by alex_b, Dec 2, 2018.
  1. alex_b
    alex_b Journeyman
    Hi all,
    Been wanting to make this thread for awhile about some general tips and tricks I've learned after cutting fiber composites and carbon fiber almost exclusively on Openbuilds machines for 2+ years and over 3 separate builds, first a modified OX, then C-Beam, and now finally a brand new custom build, the TACIT RONIN II.
    I've put together a short video outlining a few key tips about machining composites as part of our latest project release I've been working on for the last number of months.
    I'll elaborate on each of the main points a bit here:
    1) Burr tooling seems to give the best results in composites bar none however there are some caveats. Non-burr tools CAN be used to cut fiber composites (specifically PCD Diamond coated routing tools) if your machine is rigid enough. It is certainly preferable to create chips instead of dust, however, even using the top coated fluted endmills, significant secondary dust WILL be created. Some further points about Burr tooling:
    • When burr tooling becomes dull, it is very obvious on the bottom edge finish of the cut. Using sharp tools is a must for clean edges and burrs wear quite fast. Typically I use using solid carbide chipbreaker or diamond-cut tools, which can cost as low as $2-3 per unit. A carbide tool will be become dull within two to three 1 sqft. pallets of parts and need replacing. PCD or CVD Diamond coated tools will give tool lives about 3x longer but at 6x the unit cost.
    • If production is your game, its best to stick with cheaper carbide burr tools in bulk and replace them more often, than go with more expensive coated tools in the long run.
    • If you do mainly one off parts occasionally, then it might be better to go with PCD, CVD or AlTiN coated burr tools.
    MY SOURCE FOR BURR ENDMILLS (US BASED)
    Some excellent composite machining content I've come across:
    Titan teaches on Machining Composite G10 - CNC Machining Education
    Successful Machining of Composites
    How to Machine Carbon Fiber and Today's Difficult Composites
    2) Carbon Fiber and composites tend to like high RPM's from 10,000 and higher. Check out the datasheet put out by Amana Tool, it tough to find real datasheet on speeds and feeds for burr tools, so have a look if you are looking for a reference!
    Amana Tool Composite Speeds and Feeds Datasheet
    I say, "tend" to like high rpms because, unlike metals, many composites don't follow the same fabrication rules as metal alloys, so what one company calls "carbon fiber" could only be a percentage of carbon with the rest being polyester filler, so ultimately hard speeds and feeds data when it comes to composites is only useful to a point. Nothing will beat empirically derived data from the specific material you are trying to cut as well as other factors the strength of coolant, depth of cut, etc.
    Machining Graphite (Check out the RPM's used)
    3) I consider flood coolant a must when cutting with burrs due to two factors.
    • Clearing swarf and heat dissipation. Small micro flutes have trouble evacuating gritty swarf on their own and the cut will start to pack. Packing leads to rubbing, rubbing leads to heat and, since composites are bound with epoxy, the heat will both destroy the endmill and melt/scorch the material.
    • Respiratory hazard. When excessive silica or carbon fiber particles get in your lungs, they don't come back out (silicosis). A flood blast + coolant shoe eliminates both dust and spray. However if you have a powerful shopvac with a very fine dust filter, it will certainly cut but isn't something I would personally play around with. (a highly sealed dust shoe can work to cut CF dry but is is a n o j o k e level of vacuum dust extraction.)
    Datron CleanCut Milling Chip Extraction System (check out what is required in terms of dust extraction)
    Thanks everyone, looking forward to completing a complete detailed build thread soon!
    I'm also working on a playlist compiling the best of the publicly available information on composite machining as the videos can be quite obscure and hard to find, so subscribe to our YouTube channel, or just hang out around here, I'll post it when its ready.
    I have a real passion for composites, I believe they are the future in so many industries, so I hope this info can find itself useful to you!
    Alex
    P.S. If you think you like that Made-with-Openbuilds utility knife, you can check it out here.
    brettzky10, Mark Carew, Giarc and 5 others like this.
  2. Glen J
    Glen J New
    Alex,
    I plan on cutting some thicker (5mm) carbon plate with my WorkBee 1050. I've made an aluminum base plate with plastic sides that I'll clamp the carbon to then fill with water. Have you experimented with submerging parts and if so, how does the cut/finish compare to your flood/jet method?
    Glen
  3. alex_b
    alex_b Journeyman
    Hey Glen,
    Submerging parts definitely works, but i would only use a DOC (depth-of-cut) of about 1mm. It only uses the bottom tip of the tool which is unfortunate for wear but what you avoid is that nasty swarf packing problem.
    The 2nd thing I would suggest is to cut a profile of your part a depth of a couple mm in your waste board before you place your stock material down. That way the tool is able to cut that last pass with minimal deflection. Good luck!
    GrayUK likes this.
  4. Glen J
    Glen J New
    Thanks for the tips. I'll post some results when I get stuff cut.
  5. Mark Carew
    @alex_b you have outdone yourself brother! The TACIT RONIN II machine is amazing! :thumbsup:
    I am heading over to KS to grab a few of these beautiful "Made-with-Openbuilds utility knives!"
    Guys, Alex has always supported OpenBuilds though donations to the FairShare Give Back Program as well as countless shout outs , word of mouth advertising and has always been an all around helpful person here on OpenBuilds.
    His amazing works speak for themselves, so please support him. Thank you
  6. brettzky10
    Hi Alex, really inspiring stuff, as someone just getting into the CNCing this post is an eye opener! I'm currently looking into building a Workbee 1010 to cut 3-5mm Carbon Fiber, and the kits typically come with a DeWalt DWP611 1.25hp which has a no load speed of 16,000 - 27,000rpm (which you mention is a good range). My question is will this be enough to cut the 5mm or should i upgrade to a more powerful spindle like yourself?
    Also, after seeing this preview and how you transitioned to a smaller, more rigid frame (mostly in the z axis it seems) I think I might hold off until you post the full build thread.
