CNC XPRO3 not locking. Only green power leds visible.
Discussion in 'Controller Boards' started by KEN MACDONALD, Feb 16, 2020.
  1. KEN MACDONALD
    My CNC Xpro3 controller board has been working fine up till now. Today the setting $4=1 changed to 0, so I had leds on but no stepper movement. I reset it and now I have both green leds on showing power, but no leds on the stepper motor connections and the motors are not locking. I checked and had to reset almost all of the default setting for my OX CNC. Still nothing. Is there a reset button somewhere or should I reflash the board. If I need to reflash, how do I do it on a MAC.
    Sounds like you had an EEPROM reset, so it wiped all Grbl settings (not just $4).
    Restore your last saved settings / last profile you used. If you don't have a saved set of your settings, you'll have to set it up again.
    $4=1 is needed to set the correct mode for the drivers
    $1=255 is needed to "lock" the motors always on
    See gnea/grbl for all the details
  3. KEN MACDONALD
    Thank you, I've reset everything and it now works ok
