Cnc Router/lathe
Discussion in 'Concepts and Ideas' started by Mike Jeff, Dec 20, 2019.
  1. Mike Jeff
    Mike Jeff New
    Forgive me because I know next to nothing about cnc machines:
    I run a woodshop and am expanding my operation to making custom stave drum sets. This requires a huge lathe or a router jig to round the drums. So my idea is a cnc machine that has an x and a z axis with a router gantry - then the drum is connected to a chuck that just spins slowly while the router does all the moving and work. Sorry it’s kinda hard to explain. Any help or guidance or if this has been done before would be greatly appreciated!
    -Z range of motion would need to be about 8”
    -X range of motion would need to be about 20”
    like this?
  3. Giarc
    Wow! That guy is brilliant. I wish he went into a little more detail regarding the software set-up he did. I will look and see if he has more info.
    Mike Jeff likes this.
  4. David the swarfer
    Just contact him (-:
    He is using LinuxCNC for the control, GRBL based controllers cannot do the rotary axis so you are going to have to use LinuxCNC or Mach3 (or a similar commercial product) that can handle rotary axes properly.
  5. Mike Jeff
    Mike Jeff New
    Wow that is
    exactly w
    Wow that’s exactly what I need... That set up is incredible! Thanks for the link, I’ll need to contact him
  6. Rob Taylor
    As a LinuxCNC user... If you want to focus on making stuff and not getting bogged down with learning machine control historical theory and programming, go for the Mach 4 controller option. More expensive, but you'll be up and running in no time.
