CNC Plunge issue
Discussion in 'CAM' started by Guillaume Junger, Aug 16, 2020.
  1. Guillaume Junger
    Hello guys.
    For some couple weeks now i'm the proud owner of a 1515 C-beam lead CNC.
    Makita router on it and a blackbox to manage all that stuff.
    So i ran into a little issue.
    For some reason (unknown to me of course) when i do pocket milling it does 5 passes at 2mm (perfect it's what i asked !) and then plunge directly to the final depth wich is 25mm. I let you image the noise and stress when this happen on my oak board project ...
    I tried 3 times with generating the gcode every time and same outcome every try ;(
    I use OB Cam and OB Control
    Does someone have a little clue ?
    Guillaume from France.
    #1 Guillaume Junger, Aug 16, 2020
    Post your gcode file, so we can check it and also post a workspace export obc file (from file menu) so we can check your toolpath parameters
  3. Guillaume Junger
    Here we go !
    Simple aperitif tray.
    I looked at the gcode and after -11 it jumps to -25 :(
    Will check soon as I am in front of PC, thanks for posting the files.
    In the meantime what happens if you try different pass depths? For example 2.5mm passes to 25mm max depth?
  5. Guillaume Junger
    Same issue.
    -7.5 by 2.5 increments and directly to -25
    #5 Guillaume Junger, Aug 16, 2020
    I am unable to import the Workspace Export (corrupted data) you can Post the original dxf/svg file so i can try setting up the toolpath, but either the file, or the current workspace, has issues. Start in a new workspace from fresh, or check the file for issues.
    #6 Peter Van Der Walt, Aug 16, 2020
  7. Guillaume Junger
    Hello.
    I started with a fresh workspace and reset all settings. Set them back and voilà ! Works like a charm. But i don't understand where and when i messed up :(
    Now i know how to solve this issue.
    Thanks for the quick reply Peter !
    Guillaume J from Zura Lagun
    #7 Guillaume Junger, Aug 17, 2020
