CNC Conversion, Smithy Granite 1340
Discussion in 'CNC Mills/Routers' started by Nicholas Emord, Feb 1, 2021.
  1. Nicholas Emord
    Looking to convert my Smithy Granite 1340 to a CNC with the Black Box. Has anyone had luck running 4A Steppers with the Drivers that come on the Black Box system?
    Amperage is but one parameter
    Check all the parameters, or provide a motor datasheet
    Coil Voltage: ideally 3-6v
    Inductance: Ideally under 10mH
    Current 1.2-4A
    If it doesn't meet these specs perfectly, provide the specs, we'll be able to tell you what to expect
    4A is the peak value for the motor (exceed that and the motor gets damaged) - most steppers run much smoother and nicer well below their maximums, but even then, BlackBox has 4A drivers.
  3. ljvb
    ljvb Well-Known
  4. Rob Taylor
    Generally speaking a lower-inductance NEMA34 is gonna give better performance over a higher-inductance NEMA23 for the same torque range, at the expense of typically higher current draw and higher voltages required. I used NEMA34s on my mill conversion: Grizzly G0758 Benchtop Mill Conversion
    The bigger issue with combo mill-drills is swapping over spindles, reorienting coordinate systems, etc. It's usually more than grbl can take very well, unless you're happy to spend a lot of time unplugging and replugging cables (lathe Z to mill X, lathe X to mill Y, etc) when you move from one to the other. To run it as a true mill-turn with static and live tooling is (sort of, relatively speaking) simple, but beyond the capabilities of grbl as well.
    I'd spend a lot of time researching how other people have converted their mill-drills before deciding anything in particular about control firmware or motors. Look at the larger picture first.
  5. ljvb
    ljvb Well-Known
    Linuxcnc is what I would recommend for that kind of mill
