Cnc a column for kitchen island
Discussion in 'CNC Mills/Routers' started by Daniel Gliniak, Sep 27, 2022.
  1. Daniel Gliniak
    Hi yall,
    I am planning to cnc a kitchen island column with my cnc. I plan to cnc 3 sides, and keep one side flat. I was wondering if someone had some experience doing this.
    I did see this guy use one of those shakesparrow cnc machine
    and was wondering if yall had any other tips or things i should be cautious of.
  2. Alex Chambers
    Have you got a sketch or cad design of what you are trying to achieve? Alignment and registration are the issues with a job like this.
  3. Giarc
    I really liked his method of alignment in the video. It has got me thinking...
  4. Daniel Gliniak
    I am planning to make it in 4 parts, because I have the 1515 cnc, so the z axis is about 2.375 =~60mm, the model is 170 x 876 x 200mm. I may shrink the width and depth a bit, and also surface the spoiller to allow more clearance. The center spiral piece is X x Z 190 x 150mm, maybe I should redesign it to be easier to cnc together.
