Closing a File
Discussion in 'CAM' started by Tahir@NY, Feb 4, 2024.
  1. Tahir@NY
    Tahir@NY New
    Hello,
    It may be silly question, how do I close an openfile in Openbuild software. It seems that it there is no close g code file option.
    Thank you
    why?
    it does not hold the file open so if other software (CAM) needs to rewrite the file, it can do so at any time.
  3. Tahir@NY
    Tahir@NY New
    Thank you for your reply.
    I can think of 3 reason that I encounter
    1. Accidently run job button get pressed
    2. love the no hold file open feature, Often I re-create the file, and forget if I loaded the latest version, end up opening it again
    3. Sometime, I need the table view without any design to place my spindle in the correct spot
    I hope this make sense :
  4. David the swarfer
    create for yourself a small gcode file that does nothing and load that when you want to be safe
    Code:
    G17 G21 G90
    M5
    M30
    Unconventional, but can be done. Clear the gcode editor, then "update" the blank view
  6. David the swarfer
    aha, didn't think of that (-:
  7. Tahir@NY
    Tahir@NY New
    Thank you for your reply and the solution.
