Chinese Linear rails or V-Wheels ?!
Discussion in 'Concepts and Ideas' started by Fancy, Aug 25, 2018.
  1. Fancy
    Fancy New
    I've been intending to build an OX but due to the unavailability of v-slot extrusions locally, i postponed my plans. Now the extrusions are available and i have more money to put in the build and i was thinking of using Ball screws but after calculating the cost i've found that it would be some what the same cost to build the machine using chinese circular linear rails or square rails with beefier extrusions. the largest i can find locally is 40x80mm T-slot that has thicker walls than the v-slot so which route do you think i should go ?
    #1 Fancy, Aug 25, 2018
