Chinese 3040 cnc.
Discussion in 'General Talk' started by Edong1174, Oct 7, 2022.
  1. Edong1174
    Edong1174 New
    Hi guys I am new to cnc and I replace my existing chinese control box that come with it when I bought the unit. with black box motion control.
    The machine movement are fine, Homing is ok. But when the machine start to run, it stop on z axiz..
    The total length of the Z axis is 100mm.
    The machine lead screw is 10mm with 12thread/inch 20221006_233709.jpg 20221006_232647.jpg 20221006_233709.jpg 20221006_232647.jpg
    Post your GCODE file please
  3. Edong1174
    Edong1174 New
    This are the machine settings.
    Walk me through if I didn't send the right info..
    Thank you
    Ed G
    Attach the actual GCODE file, we want to look through and see if any moves are high
    Next up, did you check your machine is setup correctly (Jogs move per the Cartesian standard?) and that all axis were calibrated?
  5. Gary Caruso
    Are you sure? Might need to carefully measure a full turn of the screw and see how far it travels, best to keep it all in mm for the maths.
    Gary
  6. Edong1174
    Edong1174 New
    Hi
    I hope is this it..if not please let me know where and what command to input it.
    Thank you Sir.
  7. Edong1174
    Edong1174 New
    That's the homing of the machine..
    Thank you sir.
  8. Alex Chambers
    No, please upload the actual g-code file - the file you uploaded to your controller. Camera shots of a screen are really hard to read.
  9. Edong1174
    Edong1174 New
    Hi
    I finally get the proper set up please see attached video.
    The machine is working fine.
    Thank you sir.
    Sincerely yours
    Ed G
