Can't place tabs
Discussion in 'CAD' started by KEN MACDONALD, Dec 23, 2020.
  1. KEN MACDONALD
    I'm having more problems with SketchUp/SketchUCam. I select tabs, but cannot place them on the drawing. I think there must have been an update at some point, because all sorts of odd things are happening with this programme combination. I'm going to look for an alternative. I have, and use CorelCad2020, but it doesn't have a code facility. Any ideas anyone.
  2. JustinTime
    JustinTime Veteran
    I can not recall what I did, a long long time ago, when I couldn't place the tabs. I think it was when making the cut lines, inside or outside, didn't produce a face. Post your project here, if you don't mind, and we'll look into it and see why it does it.
  3. KEN MACDONALD
    Thank you, I've attached the file.
    Ken
  4. Giarc
    I opened your file and placed tabs with no modification to the file. I am using Sketchup Make 2017.
  5. KEN MACDONALD
    Thank you, definitely a bug somewhere. I am using the same programme, but on a Mac. I’ll delete it and reloading think. Thank you
  6. JustinTime
    JustinTime Veteran
    I too had no problem with the tabs. I even tried it on the round inside cut part with no problems.
    I have the 2016 version of SketchUp v17.2.2555 on a Window machine.
  7. KEN MACDONALD
    I’ve reloaded everything and have redrawn the items. Now seems to work ok. I’ve yet to try cutting out on UGS
