Can't convert G-code from ArtCam for my openbuild blackbox software
Discussion in 'OpenBuilds Forum Help' started by Macovei Daniel, Feb 23, 2023.
Tags:
  1. Macovei Daniel
    Well i have blackbox x4 and i'm using artcam 2018 and carveco but when i save my projects the open build software font open my g-code
    Error "the gcode file u loaded contains g53 commands
    Pls make sure to home the machine to establish the machine coordonates g53
    My machine runs g54 as i know
    I'm newbie so please be patient
    Thabks
  2. Alex Chambers
    Please upload your g-code file.
    G53 is the machine co-ordinate system, G54 is the first of the workplace co-ordinate systems
    We need to ssee what those G53 commands are.
    Its not an error. Its a reminder to HOME!
    You haven't yet, and there are some Z safe moves or similar in G53. Don't overthink it. Just HOME as requested
  4. Macovei Daniel
    this is the g-code toolpaths
    If you have not homed yet, its warning you its not homed: Check if machine is homed and if any G53 moves are in the GCODE, Ask to Home · Issue #219 · OpenBuilds/OpenBuilds-CONTROL
    Note the wording of the message: "TIP:..." - its of course up to you to decide whether to ignore the advice, but homing is always a good idea
    The sample file you uploaded is not one that contains G53 and does not raise the message either - but your other file might have.
  6. David the swarfer
    no G53 in that file, but it does have a T1M6 toolchange which you will need to remove.
    some resources for you to learn from: (knowledge is power!)
    the what and how of G53
    Home, Fusion360 and G53 Z moves
    if your machine does not have home switchesm then you need to fake it
    How to 'Fake the home'
