Can you use a Makita RT0701C 1-1/4 HP with the OpenBuilds Spindle Mount
Discussion in 'CNC Mills/Routers' started by jda70az, Apr 20, 2021.
  1. jda70az
    jda70az Well-Known
    Question is in the Title. I did read somewhere that the housing for the Makita is 65mm I.D.
    and that the Open Builds Spindle Mount is 71mm I.D. True?
    I do have the Bosch Colt but the housing on that is utter garbage.
  2. Giarc
    The Makita is 65mm. You can get 65mm spindle mounts from all kinds of vendors -- mostly from Asia. But, if you want one quick Amazon may be your best bet. Or, 3D print a shim for the OpenBuilds model. Spindle Mount Adapter for Makita RT0701C
    jda70az likes this.
  3. jda70az
    jda70az Well-Known
    ok cool thx.
