Can I use Nema 17 (12-24V recommended) with 36V?
Discussion in 'Motors' started by P01, Feb 23, 2020.
  1. P01
    P01 New
    Is there any problem if I use 36V power source with DQ542MA (with correct current limit) and Nema 17?
    The motor's webpage says: 12-24VDC (Recommended).
    Is there any reason why 36V would not be Ok?
    I have read that the maximum voltage depends on inductance L [mH]:
    Vmax = 32 * sqrt(L)​
    So, in this case the maximum voltage would be 53V.
    #1 P01, Feb 23, 2020
  2. Gary Caruso
    Yes, will not be a problem, the driver will current regulate, higher voltage gets you more speed potential.
    Gary
    Peter Van Der Walt and P01 like this.
