Can Cam Group Cuts?
Discussion in 'CAM' started by Jaz, Sep 28, 2019.
  1. Jaz
    Jaz New
    Wondering if Cam can group cuts paths that are nearest to the current cut path.
    I'm noticing my home built plotter running GRBL 1.1 runs all over the map and it would really save time if it stayed in one area working on one cut path and then moved to a neighboring path instead of a cut path far away.
    Not automatically at this time, but you can create multiple toolpaths, and by working in thw order you want to cut, add entities to toolpaths that make sense to you
