Calibration Black box
Discussion in 'Controller Boards' started by dfox1787, Nov 26, 2019.
  1. dfox1787
    dfox1787 New
    Hi Guys
    I have a Workbee 1000x1000 with black box controller.
    When i am pocketing squares they are coming out fairly accurate but when im pocketing circles they are alot smaller in size than they should be.
    8mm circle is coming out at 7.2mm
    any suggestions? not sure its a controller issue but maybe someone can point me in the right direction.
    #1 dfox1787, Nov 26, 2019
  2. Ariel Yahni
    Ariel Yahni OpenBuilds Team
    Have you tried the calibration help in OpenBuilds CONTROL software?
    Just in case are you running outside / inside or path operations for both cases?
  3. dfox1787
    dfox1787 New
    Both operations are pockets which are done on the inside of the vectors. I have calibrated using the wizard and also manually.
    Its odd how its slighter over when doing a square but really under doing circles. Increasing steps will only increase both the circle measurements and the squares measurements.
    Ive had the machine in bits today re tightened everything and doubles check its square etc.
  4. Ariel Yahni
    In what software are you creating the vector?
    What are you using to make the tool path.
  5. Christian James
    Christian James Journeyman
    I would say that using calipers on a hole that small is unlikely to yield accurate measurements. A hole has round edges edges, calipers have square edges. The proper test is to use a telescopic gauge, or even a drill bit.
  6. dfox1787
    dfox1787 New
    im using both fusion and Vetric aspire.
    ill attached gcode
  7. dfox1787
    dfox1787 New
    thanks for the tip. The 8mm drill doesnt fit. Im milling 8mm holes for threaded inserts.
  8. dfox1787
    dfox1787 New
    these are what the holes are coming out like.
