Calibrating C.S. with larger than 100mm Parameters?
Discussion in 'Control Software' started by WR_Rider, Sep 25, 2019.
  1. WR_Rider
    WR_Rider New
    Sorry for the odd topic header.
    I find myself not getting round circles with my setup. Every thing seems smooth and such and no noticeable backlash. All new with only a few test runs. This is with the blackbox and control software. Workbee 1010 and bosch router.
    I tried a couple of times using the calibration wizard to set x,and Y. The wizard using a max of 100mm for a distance to tune with. I was wondering if there was a way to find the error rate at a larger travel distance, say 900mm and enter that? Do you think that might help any? Where would I enter the calibration number if this is possible?
    Thank you for your time and have a great week!
    Doug
  2. sharmstr
    All the wizard does is set the values in $100, $101 and $102. You can calibrate yourself easily:
    Though non-round circles are almost never calibration (after doing it once) but almost always mechanical (loose coupler/pulley/stop collars, loose wheels, belt tension wrong, something else loose or wiggling that shouldnt)
  4. WR_Rider
    WR_Rider New
    Thanks for the help.
    I found out why I wasn't getting round holes. I had a couple of loose bolts on the side gantry plates. However, after tightening them up I now have binding at both ends of the axis's. Still not sure its actually binding or the motors are not getting enough juice.
  5. Rick 2.0
    Did you lubricate the screws?
