CAD files for C-Beam Linear Actuator Bundle
Discussion in 'Other Builds' started by newtoopenbuilds, Jan 19, 2024.
  1. newtoopenbuilds
    Hello, I chose 500mm and clicked CAD. However, it links to the 250mm version. Moreover, it is in stp format only.
    C-Beam® Linear Actuator Bundle - OpenBuilds Part Store
    Is it possible to obtain the CAD files, ideally in SolidWorks format, for both the 500mm and 250mm versions of the C-Beam Linear Actuator Bundle?
  2. Giarc
    Can you not import a step file into solid works, move the end plate 250mm, then extrude both the extrusion and screw? That is how I did it in Fusion360. It was pretty straightforward.
