C_Beam X5L Hybrid_Tank
Discussion in 'CNC Mills/Routers' started by HC.Carbo, Feb 26, 2018.
  1. HC.Carbo
    HC.Carbo Journeyman
    Trying the multi axis swarf tool...spectacular...but epic fail. :)
    Second attempt was going better (only little flaw) , soon video
    Lucky me, i was cutting foam :)
    eyes done with swarf
  2. HC.Carbo
    HC.Carbo Journeyman
  3. HC.Carbo
    HC.Carbo Journeyman
    Maybe i should learn first to cut something on the 3 axes :)
    g53 lol, i don't get it. :D
    Homing all axis > once hit the home/limit switch it returns x steps (1mm)
    so you are now on x,y,z 1mm > from here i set my g54
    then your post does g53 and your zero is at that 1mm o_O
    so my g54 was always off :D
    ctrl box (attempt)
    mmm how do i get my wires out ? :D
  4. HC.Carbo
    HC.Carbo Journeyman
    omg,
    My table had some strange behavior & belt was already loosen.
    Opened the whole thing, seems there are some huge flaws.
    see pic, treads have different sizes, so the screws are to small.
    left:3.8mm, right:2.8mm the screw goes true the 3.8mm to the belt drive 2.8mm
    also some play on the shaft/bearings
    update: ok, the shaft was not in place.
    still some play, belt (ad some wheels din't help much)
    v wheels good for everything :)
    #34 HC.Carbo, May 1, 2018
  5. GrayUK
    There's that great Chinese Quality Control again!! :banghead::banghead:
  6. HC.Carbo
    HC.Carbo Journeyman
    ah, my belt has left the transit zone :ROFL:
    Meanwhile...may the 4th be with me.
    (aim is to put the 5th from the Chinese on to this one o_O )
    (will test the belt first :D )
  7. Mark Carew
    A fail never looked so good!
    Awesome stuff @HC.Carbo :thumbsup:
  8. HC.Carbo
    HC.Carbo Journeyman
    ok, placed a new belt. Turning the table over the axis was never so smooth.
    See to test it next weekend.
    Meanwhile some 4th axis play.
    Adaptive& parallel (flat end mill)
    was cutting @ 3mm...now i know what they mean with chips instead of dust (i usually have) :D
    GrayUK and Scotty Orr like this.
  9. HC.Carbo
    HC.Carbo Journeyman
    GrayUK likes this.
  10. HC.Carbo
    HC.Carbo Journeyman
    soon back to 5x,
    Last week first attempt to cut 4mm acrylics...omg my first cut :ROFL: guess you know what went wrong :)
    After lowering the spindle speed & increase the move speed it went much better :)
    Still not that good, to much play on the z, moved the spoiler board 8cm higher and got very nice results (y)
    (also switched the 30cm c-beam on the sides by 50x8cm rails so i could put the x on the back (instead of on top the c-beam)
    so far my ctrl box, hope no court-circuit :nailbite:
    GrayUK likes this.
  11. HC.Carbo
    HC.Carbo Journeyman
    What you see is NOT what you get...Fusion360 multi axis :D
    Lot of times the lead in/out will ruin your cut.
    Guess i have to play more with the settings.
    Here my foam dummy to test tool path's :D
    front/back ok,
    Flow on the sides (rounding) does a strange move (but does the job)
    Giarc, Mark Carew and GrayUK like this.
  12. Mark Carew
    This build journey has become such a great learning experience on multi axis milling. Thank you for taking us along for the ride @HC.Carbo :thumbsup:
  13. HC.Carbo
    HC.Carbo Journeyman
    cut of the weekend, do you know what this is Mark ? :)
    bang my head, went wrong after i changed the tool for a finishing pass (forgot to move up the Z )
  14. Mark Carew
    My guess is it may be have something to do with kraftwerk or manneken pis or both? :)
  15. HC.Carbo
    HC.Carbo Journeyman
    Almost, but WRONG :) ( yes, we call him Manneken :) ...)
    Depeche Mode (one night in Paris, back screen) by Anton Corbijn
    still have to cut a Bong speaker... :) (have printed versions)
    some entertainment between the cut's :D ^_^
    Ryk likes this.
  16. JustinTime
    JustinTime Veteran
    Why did you cut into the endgrain? The part comes out very very week.
  17. Mark Carew
    Dang it! well for whats its worth, I initially thought 'I bet this has something to do with Depeche Mode' :) Cool stuff man and great video! I like the part where Manneken claps and the particle effect bounces on the floor, nice one! Thanks for the share.
    HC.Carbo likes this.
  18. HC.Carbo
    HC.Carbo Journeyman
    just a piece of wood laying around, ah oh i see
    End Grain, Edge Grain, or Face Grain
    Had no clue :)
    thx for the tip (y)
  19. Beëlzeblub
    Godverdomme deze is echt cool :) so almost finished the build?
  20. HC.Carbo
    HC.Carbo Journeyman
    de 30cm c-beams nog te vervangen door 50cm, zou het zowat moeten zijn. :)
  21. Beëlzeblub
    Echt cool uw build man! keep up the work!
  22. HC.Carbo
    HC.Carbo Journeyman
    check last cut :)
    V_rail Racer
    ok, seems my ab table holds well with the new belt :) (still, pretty sure not suited for hard materials if you want precision stuff ! )
    notice that even the hexagon table has not even edges :) :) :)
    only front & back of the car is multi axis,
    (impression that f360 has still a way to go, once you use a spherical shape > no go. Don't think it's the post, test it with the big ones= same results)
    pocketing with indexing (headlights & logo)
    cnc: overlooked one thing...the noise it makes OMG :D
    Rick 2.0 likes this.
  23. HC.Carbo
    HC.Carbo Journeyman
    still running :)
    Checked today the simultaneous 5x in fusion again & it went pretty good ? :)
    Because those ytubers seems to buy all big 5x machines and they work in fusion360 :D (want us to believe)
    Boom Boom ;D
    Giarc, GrayUK and Gary Caruso like this.
  24. HC.Carbo
    HC.Carbo Journeyman
    Happy Easter to :)
    GrayUK, Scotty Orr and Rick 2.0 like this.
  25. HC.Carbo
    HC.Carbo Journeyman
    a last pic before i strip it down.
    it was a nice journey that brought me to operate a 5x dmg mori (heidenhain/hypermill) o_O ...
    left: 2 4th axis for 5x simultaneous : mach4/Fusion360
    right: vise, temporary ad x/y table for some laser work with grbl :)
    Grts,
  26. Rick 2.0
    Where to next?
  27. HC.Carbo
    HC.Carbo Journeyman
    something more rigid :) :) ;) (kit with high Z , so i can still use my controller & 4th axis)
    the search for a new one seems to be hard, no reply's, no stock, only the real expensive ones do reply! ...
    my eyes on a german one but, reply once a week so it takes +3 weeks to get your invoice + 3-5 weeks shipping time. OMG
