C channel cart parts?
Discussion in 'Other Builds' started by Benn, Apr 7, 2023.
  1. Benn
    Benn New
    Hey peeps,
    I want to sandwich 2 xl gantry plates on each side of the c channel but I don't know which spacers and poly lengths to order.
    Has anyone done this that can give me the parts I need to join the plates?
    If you're referring to the standard X or Y gantry stack, there is a 9mm spacer between the wheels and a 6mm spacer each side outboard of the wheels. There is also generally a 1mm spacer each end of the stack, up against the plates.
    If that's not what you're referring to, we're gonna need a sketch to understand what you're asking.
    Poly?
  3. Benn
    Benn New
    That was supposed to say bolts
  4. Benn
    Benn New
    So for each set of wheels the spacers I'll need are:
    1mm |6mm |wheel |9mm |wheel |6mm |1mm
  5. Rick 2.0
    Sorry, I got the 1mm washers backwards. They should be between the 6mm shims and the wheels as shown.
    The bolts are 65mm and you need a Slot Washer - 15x5x2mm - OpenBuilds Part Store on the back side under the nut.
