C-Bot
  1. Val Cocora
    Val Cocora Well-Known
    anything up to 1270 x 1095 x 1145 mm printing volume.
    the extruder is an all metal dual from micron 3dp, goes up to 450 celsius hotend temperature, which means even some ceramics can be printed on it.
    my kid, pictured, is there to give a reference about size.
    Carl Feniak likes this.
  2. Raldan
    Raldan New
    Check out matterhackers.com for their take on E3D heatbreaks (Clean Tip $24)or their replacement E3D heatbreaks are listed for $20. I've bent a couple and their Clean Tips are better than the origs (or so they say). They've worked okay so far for me, but I've tried not to ram them into the side of my bed like the old ones.
  3. CapnBry
    CapnBry Well-Known
    Yeah I've done a lot of PETG printing recently because it looks so cool and doesn't warp as easily. I had a ton of problems up front like you describe, where small fibers of filament collect on the nozzle over time and eventually form enough of a blob that they deposit and make an immovable solid lump that will eventually shift the print. This print looked so dialed in when I left it though that I didn't think there would be any problem. I've studied this print pretty intently and I do see that about 2 layers before it was all messed up it looks to have shifted off slightly, so clearly there was an issue. I don't see anything that would cause everything to go so far out of whack to send the print head 100mm off course and apparently slamming repeatedly into the lead screws.
    The somewhat good news is I was able to straighten the heatbreak out with a little brute force. However there was some damage to the threads so it doesn't screw into the heatsink all the way any more (and I don't want to force it or it will just tear up the aluminum threads in there). I extended my PFTE tube from your direct drive extruder the extra distance (only about 2mm). Re-zeroed my Z-axis, reprinted the exact same gcode and it came out beautifully. I watched it the whole time waiting for something to go wrong but "A Watched 3D Printer Never Boils".
    @Raldan those look awesome but I was hoping to go the other way with price, something cheaper not more expensive! I'll admit I thought I needed to replace my heaterblock though because of how pretty and clean theirs looked.
    Raldan likes this.
  4. trublu832
    trublu832 Well-Known
    Has anyone experienced under-extrusion but only at the beginning of a line segment? The nozzle will go to a position and move and for the first centimeter or so will thinly extrude or leave blobs but eventually it prints out a solid line. I've tried forcing extra extrusion after retract but it doesnt seem to help.
  5. Carl Feniak
    Carl Feniak Journeyman
    Not that I've noticed. The extra is meant to compensate for nozzle leakage, but I've never made use of it. Are you retracting a large distance?
  6. Chris Roadfeldt
    Chris Roadfeldt Journeyman
    Off the top of my head.
    Check your filament diameter and slicer settings match up.
    Extruder calibrated? Digging / slipping? If slipping, check your retraction speed as well.
    If retracting a lot, check if stepper is skipping steps because of filament hardening in heatbreak causing a partial blockage. Blockage might clear when pushed hard enough into heat zone again.
  7. trublu832
    Just 4mm, its not really leaky, just seems like delayed start on each line segment. I've secured the bowden tube at each end to avoid the tube moving during retract
  8. trublu832
    Thanks for the ideas. For those reading along in the future wanting to avoid the same problem, I underestimated how tight the extruder bearing spring needs to be, I replaced it with a much stiffer spring and now each line and circle extrudes fully right where it needs to.
    Muh_3d and Chris Roadfeldt like this.
  9. Carl Feniak
    FYI, finally started updating the BOM last night. 50% complete.
    adamcooks, Sk8rSeth and Muh_3d like this.
  10. Val Cocora
    are you using any particular software for that?
  11. Carl Feniak
    Just excel for the bill of materials, nothing fancy but gets the job done. Is there a program you like to use?
    The biggest issue I've had in the past is that any linked information eventually gets broken as sellers modify their websites. My only counter to this is to add cell comments that say "Search: XXXXX" for ebay items as they can relist or other sellers will have similar listings. Also, no single store has everything required/desired.
  12. trublu832
    Maybe export it as a pdf as that seems to be a more universal format in case people don't have excel or something compatible.
  13. Carl Feniak
    Can do, but then the extrusion length calculator won't work. I can just preconfigure a 12" x 12" bed setup for display I guess.
    Also, is there a pdf converter that will maintain the cell comments/notes? Or do they need to be broken out to another column?
  14. grat
    grat New
    I vote to keep it in Excel. Worked just fine for me in LibreOffice (ie, openOffice) which is free and multi-platform.
  15. Chris Roadfeldt
    I might be able to help put something together to automate all this. The BOM, calculator, etc...
  16. trublu832
    I forgot about page 2, nevermind
  17. Val Cocora
    i was asking because i use autocad's attribute extraction feature. once i define, say, a single t-nut as a block, i can attach attributes to it, such as price, manufacturer, contact no., etc.
    then, a simple count of them in all the drawing gives me the total no., total price, etc.
    same goes for any possible item, thus resulting the BOM in various formats, excel included.
    kinda was hoping there's a better method out there.
  18. Val Cocora
    x axis belts installed and tensioned today.
    tomorrow, same thing for y axis.
    the new port extruder front plate works great, no more danger of timing belts rubbing against the stepper contacts at extruders. unfortunately, i had to lower the whole extruder assembly by some 12 mm :-(
    be it as it may, i'm finally back on track.
    hope to be ready for testing by end of february.
    NeoGames76, AK Eric, Sk8rSeth and 2 others like this.
  19. Val Cocora
    some improvising prior to installing the y axis belts.
    first had to get those pesky wires out of the way, so it fell on some shelf brackets to do the job.
    later, i will design and print some proper wire supports, but for now, this will have to do.
    NeoGames76 and Muh_3d like this.
  20. Elmo Clarity
    Elmo Clarity Journeyman
    Anyone have a favorite place for getting closed loop gt2 belts? Switching to the single motor with belts for the Z axis and I need a belt around 1250-1350mm. I found some on ebay, but they are coming from China. Hoping to find something that won't take so long to get here.
  21. Val Cocora
    you might want to try
    www.sdp-si.com
    #1701 Val Cocora, Feb 10, 2016
  22. Austin Seagers
    Austin Seagers Well-Known
    What thickness of glass are people with 300mm x 300mm beds using? My aluminium heat-spreader is slightly warped, and 3mm glass tiles bend slightly under their own weight at the two unsupported corners.
    EDIT: if you can mention the type of glass you're using, and the wattage of your heated bed also, that'd help me out. Want to avoid thermal stress with a thermal gradient between top and bottom sides of the glass by heating the underside too rapidly. Obviously this becomes more of a problem the thicker the glass pane
  23. Carl Feniak
    On my 200x300 bed I am using 3.3mm Borosilicate Glass. This type of glass has a low thermal coefficient of expansion and is used in Pyrex baking dishes. Borosilicate glass - Wikipedia, the free encyclopedia
    I am using a ~200 watt bed (again 8"x12", not 12"x12"), which is a touch under powered. Constantly on results in a ~114°C bed temp.
    My friend has a silicon 600W bed and it heats up almost as fast as his hotend! He just finished his printer and is just using standard picture frame glass. Not sure if he has any plate warp yet.
  24. TruculentMC
    My printer isn't complete yet, but for my heated bed I'm using a .25" MIC-6 aluminum plate with PEI sheet fixed to the top - no glass. I have a 450W silicone heater but it's 8x8, I'll probably order a 12x12 one instead - 120V AC heater and I'll use an SSR to control it. Still need a few more pieces of hardware, and finish printing all the parts...
  25. Austin Seagers
    Thanks guys. I'm probably going to buy some annealed 6mm float display glass and swap it for my current 3mm mirror tile to try to rid this flatness variation. UK prices of borosilicate is extortionate to say the least so i don't really consider it an option.
    FWIW anyone considering materials to use, here's what i'm using currently.
    Sandwich from top to bottom is:
    - 3mm IKEA mirror tile 300mm x 300mm
    - 3mm aluminium sheet 320mm x 320mm
    - ~300W silicone 240V heater
    - 20mm air gap using 3x M3 countersunk bolts to stand-off and level the upper layer with
    - 1mm cork insulator
    - 4mm aluminium 340mm x 340mm base plate
    600W is something to behold. Wow. Has your mate built a C-Bot or something else?
  26. Carl Feniak
    Something else. He is the one that has triggered my maker bug with our OB1.4 builds. He wanted to build a C-bot but didn't want to drop the coin on V-slot and wheels (Canadian dollar is hurting!).
    He found a coreXY on thingiverse that uses 15mm openbeam/smoothrod instead and decided to adapt it to use braided fishing line instead of GT2. <-- that part he regrets as he ended up redesigning the entire printer.
    It is a 8"x12" printer as well and I am trying to get him to share it as he is getting some great prints. His bed is a base of MDF, then the heater, with mirror glass on top.
    He is now building one of these with Nema 23s... Mostly Printed CNC / MultiTool by Allted
    I would love to design my own C-beam plate machine but don't have space for it. Maybe in a few years if I upgrade the house!
  27. Austin Seagers
    Braided fishing line? I've heard of people using fishing line as filament, but not braided as a drive belt. Doesn't sound like a great idea...
    Ah right. Are those CNC's rigid enough to require nema23's? Agreed, some of the big CNC builds on here and elsewhere are mighty tempting. Although, I keep telling myself that I should get into casting metals from a 3dprinted mould if I need anything with more strength than thermoplastic.
    On topic: I've just picked up my 6mm glass. The merchant mentioned that he regularly uses the same glass with a double glazing injection machine that squirts some clear insulating liquid/paste at 190degC onto panes at room temp! That put my mind at ease, seeing as it's considerably more stressful than what i'll be putting the panes through.
  28. Val Cocora
    i believe it's called laminated glass.
    make sure it's the right type though, lami glass can still crack, be it from mechanical stress, e.g., a sledgehammer and a persistent thief, or, in our case, temperature. its main appeal, safety, comes from that interlayer acting as a glue in case of breakage, and holding together the glass shards, big and small alike, thus preventing you from getting nasty glass cuts.
    moreover, the glass panes that form the laminated glass are regular float glass themselves, therefore they don't like sudden temperature rise and the heat expansion leads to cracks.
    below is a list of lami glass types, to get you an idea.
    What is laminated glass? | Safety Glazing Group Trade Association Group | Glass and Glazing Federation
  29. Austin Seagers
    Might be worth mentioning that the glass has been annealed, and is a single pane, not a fused double glazed pair.
    Also, the glass is not laminated as it was cut with a normal glass cutter in front of me :)
  30. Val Cocora
    my bad, i was under the impression you were going to use 6 mm lami.
    are you comfortable with annealed glass?
    from what i know, annealed glass expands a lot when heated, and since it's a rigid material, it cracks instantly when trying to expand.
  31. Elmo Clarity
    Annealed glass is nothing really special. It is what you get when making float glass. It is also what you do to tempered glass to cut it. You then have to re-temper the glass.
