C-Beam newbie needs help with new blackbox contoller
Discussion in 'General Talk' started by Jake9999, Sep 7, 2020.
Tags:
  1. Jake9999
    Jake9999 New
    Hi there, I just received my BlackBox Controller for my C-Beam. I followed the assembly video which was great. At the end, I was able to move my X and Y axis but not my Z axis. I redid the connection for Z and now nothing works. I cannot communicate the the BlackBox. I read several post regardig this and have removed all connected stepper motors and limit switches and it still won't work. I get the following message: "ERROR!: No supported firmware detected - you need a controller with Grbl 1.1x on it, or there is a problem with your controller. Closing port COM4"
    I then tried the re-flash the box using the Wizard tool and get the following message: "FLASH FAILED!"
    I have attached the serial console output below.
    I have sent a note to support last week but have yet to hear back from them. Is there anything else I can do?
    Thank you!
    Serial Console Messages:
    [11:33:36] [ 3D Viewer ] WebGL Support found! success: this application will work optimally on this device!
    [11:33:37] [ Websocket ] Bidirectional Websocket Interface Started
    [11:33:38] [ update ] Checking for Updates
    [11:33:38] [ update ] You are already running OpenBuilds CONTROL 1.0.246
    [11:36:53] [ connect ] PORT INFO: Port is now open: COM4 - Attempting to detect Firmware
    [11:36:53] [ connect ] Checking for firmware on COM4
    [11:36:53] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [11:36:54] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [11:36:55] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [11:36:57] [ connect ] ERROR!: No supported firmware detected - you need a controller with Grbl 1.1x on it, or there is a problem with your controller. Closing port COM4
    [11:36:57] [ disconnect ] PORT INFO: Port closed
    Tried to flash it with the wizard tool:
    Here is the result:
    [11:39:25] [ Firmware Upgrade ] connected
    [11:39:25] [ Firmware Upgrade ] reset complete.
    [11:39:25] [ Firmware Upgrade ] flashing, please wait...
    [11:39:26] [ Firmware Upgrade ] FLASH FAILED!
  3. Jake9999
    Jake9999 New
    Thanks so much Peter!
