C-BEAM-GTC
Discussion in 'CNC Mills/Routers' started by GinoTheCop, Mar 9, 2016.
  1. GinoTheCop
    GinoTheCop Journeyman
    Sketches are almost finished for new machine.. Double checking and trying to compact it in Fusion 360.. I plan to call it GTC 2020.
    Next will be preparing a parts list, calculating cost, design the control box, buy parts and build the machine.. Will be a good year hopefully! :)
    Giarc and Kristopher Grove like this.
  2. DHosslerLanp
    Hi Gino,
    I'd like to build a machine like this and could really use some help on the measurements for the Gantry plates. Could you tell me how they measure?
  3. GinoTheCop
    Hi DHosslerLanp,
    All plates are available in multiple downloadable formats. The links should be somewhere in the build
    Here they are once again for you:
    X-Plate-Back: https://a360.co/301Bsew
    X-Plate-Front: Fusion
    Y-Gantry: Fusion
    Z-PLate: http://a360.co/2gaIaIn
    Hope this helps. Best of luck with your build...
  4. GinoTheCop
    By the way above links are for C-BEAM-GTC machine..
    GTC2020's design is not yet finished.. (the one on the latest render captures)
  5. DHosslerLanp
    Thank you for the reply. I was able to get the measurements from fusion but when I sent them to my local CNC shop he came back and said that the plate was .6 inches thick instead of 6 mm.
    Are the measurements in these pictures correct? In mm? BF545AF4-65D7-4259-B6AD-22597F235E8A.png 40241B2C-3B21-4DEB-BB5F-123F629634ED.png B1B20C9E-D22C-4584-AA4F-2388581FFEB2.png
  6. GinoTheCop
    Please refer to below drawings..
    x-plate-back
    Fusion
    x-plate-front
    Fusion
    y-gantry
    https://a360.co/307TFHp
    z-plate
    https://a360.co/2T5kuKX
    Hope this helps. Please double check them all before proceeding. The thickness is 6 mm in my all files.. That must be a conversion problem maybe? (I never use imperial)
  7. lcreatived
    Hey! This build looks mint! Waiting the post with the parts lists. For me, this is the perfect machine; looks stiff, screw driven...
  8. GinoTheCop
    I am terribly sorry I have been fighting with cancer for past 9 months. I am all good now but the funds I need to built again is mostly gone for health :(
