C-Beam™ Machine - Plate Maker
  1. Ronald van Arkel
    You can use lubricant just on the surface, just make it "oily". Keep the bit cool and make sure you clear the bit from debris while cutting. It might be the bit that isn't made for the purpose as well; do you have a picture of it? And also a picture of what the debris looks like?
    Note, I'm also new to cutting with the DeWalt, but have used larger CNC machines before...
    -Ronald
  2. Jimmybuckets
    Jimmybuckets Well-Known
    It's a two flute designed for aluminum. I want to say is a 30 degree helix. Can take a pic later of chips and bit. A little oil may help from keeping chips from flying all over too.
  3. Rick 2.0
    You don't want oil, you want cutting fluid.
  4. Jimmybuckets
    Ideally I would like to get the feeds and speeds correct enough so I could go with no fluid whatsoever
    Joe Santarsiero likes this.
  5. Jimmybuckets
    This run totally dry doubled the speed to 1800mm/min set depth of cut to .25mm and z ramping to 15 degrees. Only issue I ran into was made my cut through too deep and my tabs too shallow. The part came loose jammed the bit stopped....much smoke from the router... hopefully it will be covered under warranty. But better surface finish! Amazingly the router will still run.
    #1145 Jimmybuckets, Jun 2, 2016
  6. Jimmybuckets
    Was able to do another run last night. 1/4" bit @2000 mm/min, 16k on a half burned up router, proper tab and cuts heights. At 0.25 mm cut depth. I still seem to be getting some spots where it seems the bit gets pulled into the part...you can see that on the corners. If anyone has some insight on why that might be happening that would be great. Also read that climb cutting was the best way to get a good finish on aluminum. I have been conventional cutting since it is easier on the machine. Think I might give climb a shot but concerned since I am already having some issues with the bit grabbing or wondering in some places. Maybe more tabs and a few more screws holding down material would help? Any ideas would be great thanks!
  7. Jimmybuckets
    Climb cutting with .25" bit at 2000 mm/min at 16000 ish rpm and .15mm step down at 10 degree and 40 mm/min z speed.
  8. Charles Roseberry
    Looks a lot better :) What cutting tool are you using? Router, Spindle and Bit? Also, where are you getting the alum? Thanks Glad you seem to be getting it sorted
  9. Jimmybuckets
    Using a Dewalt DWP611. The bit is specifically for aluminum and have had it for a long time but never used it. It is a .25" two flute. I got it from a www.American-carbide.com. There are a few sites with similar names this one has the dash in the address.
    Edit: Also I cut this totally dry btw.
    #1149 Jimmybuckets, Jun 5, 2016
  10. Joe Santarsiero
    Joe Santarsiero OB addict
    Have you tried cutting paste? I use boelube. Little on the tool and a light wipe on the part.
    You can continue dry, just expect shorter tool life. Obvious. Make sure your evacuating the chips.
    The gouging sounds like too heavy a feedrate. Tool could be done too. use a good calculator and shoot for 1.5thou chipload to start. The router speed can be tough to work with though. Single flute might be a better place to start.
    You might try a light climb finish pass. Climb is usually recommended based on the drive system. If you have slop or backlash then the results may not be desirable. You could just add a conventional finish pass. to the toolpath. a few thou is enough to clean it up.
    Joe
  11. Jimmybuckets
    Joe I will check out you suggestion on the line. A single flute would be much better but the double was what I had on hand. I have a SuperPid but haven't had time to get that hooked in yet... actually my electronics are still in a cardboard box. I read somewhere that the gouging could be an artifact of the radius of the bit and radius of the corner being too close in size...not sure how true that might be. I was thinking roughing in conventional and then finishing in climb. Climb seems to give much better finish on aluminum. Thanks for the input! He is a link the article that has the info about gouging: 11.1.2 NC machining
    #1151 Jimmybuckets, Jun 5, 2016
  12. Marvin N
    Marvin N New
    Hey guys, in need of some help.
    Have my C-beam built and I want to use Fusion 360 with it.
    I attached a picture of the settings it asks for. I am currently messing around with the settings because at first it was moving a fraction of a mm per second so I am raising the values but have no clue what I should be looking for, or what the limits of the machine are.
    Any advice would be greatly appreciated.
    Thanks,
    edit: I am using 1/16 stepping and the machine is completely stock.
  13. Jimmybuckets
    Looks like your cut speeds are set to 1.3 mm per minute. If you look a few posts back you can see my settings.
  14. Jimmybuckets
    Decided to go for some upgrades with the sale going on. I'm going to use a double xlarge gantry plate how do I figure out the spacers for the middle between the wheels. It's going to be ox style with a plate on each side of the C-Beam
    Kyo likes this.
  15. Kyo
    Kyo Veteran
    Sweet, should be a good upgrade.. The spacers needed between the wheels are 9mm.
    Jimmybuckets likes this.
  16. Jimmybuckets
    Thank you sir :) Been watching you rework idea...that will be the next upgrade! Also did the double wide gantry plate.
  17. UltiBots
    UltiBots Well-Known
    Marvin -
    I too am using Fusion 360 & CAM. On my 3rd ever part I was able to successfully cut 6.5mm 6061-T6 Aluminum dry with OK results. See gallery images and details below.
    Hope this helps...
    Brad - www.UltiBots.com
    Modified C-Beam Bundle
    Dewalt 611
    Elaire 1/8" Collet
    1/8" Single Flute Carbide End Mill
    Workflow = Fusion 360 & Cam > Chilipeppr > Tinyg
    RPM ≈ 25,000 (dial setting 5)
    Feed @ 20"/min (508mm/min), Ramp @ 5"/min (127mm/min), Plunge @ 8"/min (203.2mm/min)
    Pocket cut = 0.25mm rough & 0.2mm finish, 3mm max stepover
    Bore cut = 0.2mm pitch
    Contour cut = 0.25mm rough & 0.2mm finish
    #1157 UltiBots, Jun 9, 2016
  18. Ronald van Arkel
    Great tip, looks like I've found the collet I was looking for:
    • Dewalt Style Palm Router Collet 1/8"
    • N.º de artículo DWP-1250
    Thank you,
    -Ronald
  19. Marvin N
    Marvin N New
    Thanks for the help guys,
    I have been watching some videos and learning about how the feed and rpm affect the result.
    I have not had any time to dedicate to the cnc but the other day I cut out a little washer I made on Fusion and it worked... enough to work.
    The first move dragged the bit across the board so that's the line you see.
    I had also not leveled the spoil board on that cut yet, I still don't even have the router completely perpendicular to the xy plane.
    But wanted to make sure everything worked before I continued fine tuning everything.
    This was with a 2 flute 1/4 upcut bit. Only ever having used a router for normal woodworking purposes, I had never seen a bit grab the wood and lift it like that :eek:
  20. Ronald van Arkel
    @Marvin N,
    For wood I would use a downcut.
  21. Jimmybuckets
    You have to check your clearance height and if it ramps to clearance or goes straight up
  22. Maxime Favre
    Got mine yesterday !
    And a few plastic bags later: ;)
    crispin, Kyo, GrayUK and 2 others like this.
  23. Mike Piechowski
    Big thanks to Mark and the remainder of the OpenBuilds Team. The C-Beam machine has been an excellent introduction to CNC. I finally got mine put together, at least far enough to make some chips. I purchased it intending to primarily cut aluminum. To put things mildly, my results "out of the box" have far exceeded my expectations.
    This was cut from some quarter-inch thick 6061 from my scrap pile. My C-beam has a Makita 701 with an Elaire Collet, I used a cheap 1/8" carbide single-flute from Amazon. Feed was 600 mm/minute, with a 0.25 mm cut depth.
    While it isn't perfect, the errors are mine, not the machine's. Squaring the axes is not something to skip over in the assembly process.
  24. Mark Carew
    Awesome @Mike Piechowski ! We love to see C-Beam machines making plates :thumbsup:
    Congratulations on your Build and first cut and thank you for the kind words.
    It only gets better from here and I can tell by the plate your making you are well on your way my friend.
    Thank you for the share
  25. Brandon Raineri
    Does anyone have recommended GRBL settings for their C-Beam machines? I am really interested in seeing what kinds of accelerations and maximum speeds you are able to run reliably.
  26. Jimmybuckets
    Rigidity is the major slow down on this machine. I started out with 1/4" bits and have had ok luck with them but just used a single flute 1/8" bit for the first time with some of the best results I have had so far. I used a feed calculator and the backed off a little. Cut at 250mm/min at .75mm deep and it worked well. Also the bits were really cheap on Amazon.
    Autek 10x 1/8" Titanium Nitride Coated Carbide CNC Router Bits Single Flute Tools 17mm(1Lx3.17Tix10) Autek 10x 1/8" Titanium Nitride Coated Carbide CNC Router Bits Single Flute Tools 17mm(1Lx3.17Tix10) - - Amazon.com
  27. Jimmybuckets
    This was with the cheap Amazon bits. Conventional cutting. Next going to try conventional cut with a climb cut set of finishing passes.
  28. Mark Carew
    Looks good Jimmy. Once thing to try is to blow the chips out of the hole while its cutting you should get a much better finish on that edge. This will also keep the bit from re-cutting the chips
  29. Jimmybuckets
    Mark,
    I tried running one part conventional with 0.5mm oversized, then ran a climb file to clean up came out nice but still mic'ed out about .5mm too large. I have a good amount of preload on the z but when I grab the router and yank on it. There is some definite movement. I went through everything last week and re-tentioned every. It looks like there is slop in the bearings on the z...I have parts to upgrade to the double wide z plate... hopefully that will help but in the meantime am I just running up against the limits of the machine? Or is there something I am missing?
  30. Rick 2.0
    Jimmy, how much side to side movement do you get when you pull sideways on the spindle? If you're noting weakness there too, you might be better off with the XL Gantry Plate. It provides a wider grip which will also increase side to side stability. Also check for flexure of the thin gantry plate supporting the Z-axis as this may be a candidate for strengthening.
    crispin and Mark Carew like this.
