C-Beam™ Machine - Plate Maker
  1. Razor_McT
    Razor_McT New
    Ah, that's interesting thanks - I hadn't thought along those lines. I've got the 24V PSU from Ooznest but haven't made any changes at all to the CNC board's pots - would it just be a case of me tweaking those? Forgive my ignorance, but can I do damage to the steppers or boards if I set those pots incorrectly?
    Yeah, I seem to find a new use for those foam tiles every day!
  2. GrayUK
    Yes Razor you could potentially damage something if you go over the top. :nailbite:
    I'm afraid I can't help with regard to the correct settings, but I'm sure someone here can.
    Getting the amps right is a common and a regular problem. :banghead:
    I know it is commented on on this Forum, afraid I don't know where though.
    Sorry to be only half-helpful! :(
    Gray
  3. Razor_McT
    Razor_McT New
    No worries, thanks for the heads-up anyhow, I'll do some digging no the forum.
    btw, I've been trying to work out what spindle to use - I'd settled on the Dewalt 26200 as that seems to be what most people in the UK use, but then I came across the Kress 1050 and from other posts I've seen I think you may have gone down that route already.
    Any thoughts on the Kress vs the Dewalt for the C-Beam?
  4. GrayUK
    Kress is an excellent spindle, but very noisy by comparison to others, especially a Chinese spindle. It is very reliable and hard working. It also comes with a spare baring and bits and pieces. The usual German tech at its best! :thumbsup:
    Compared to a Kress, and you do need to get the one with the lower speeds on it, FME or FME-1, which are dearer, you can get a 800watt spindle for just a few pounds extra. Many have done so. Check out Spindle And on Ebay.
    However, weight is also a potential problem with a Chinese spindle.
    Gray
  5. Michael Shore
    I have a Kress 1050, one thing to watch is the height of the KRESS when mounted to the C-Beam machine, thedewalt mounts quite high on the body of the spindle, allowing the collet to be much lower than the bottom of the Z-Axis when lowered, however the KRESS is mounted quite close to the bottom of the spindle so limiting the amount of endmill below the Z-Axis.
    Just added the images
    My machine started out as a plain old C-Beam, but I love this stuff so Much I wanted to build my own bigger machine, so here is one of the stages it is going through during its junior months, cant wait for it to get to teenage and adult.
    Planning on 800 by 1200mm ballscrew and linear rails on all Axis, but cost is limiting me to little changes at a time.
    I have to Thank Mark and the guys at open builds for getting me into this.
    Michael
    #875 Michael Shore, Feb 16, 2016
    GrayUK likes this.
  6. GrayUK
    That sure is looking meaty!! And that's certainly an original way to drive the X. :thumbsup:
    Good job. Keep the pictures coming. ;)
    Gray
  7. Michael Shore
    it is sure heavy as well now, I have 1200mm rails on order, all being well they will arive tomorrow, and I can cut stuff again.
    As for the X, well, it was a case of, I already had the C-Beam and screws, and ballscrews and supports are divorce material :(, well this month they are anyway. But now I have the rails en-route, I can get everything back together until I can afford to make a new frame and make it 800 x 1200, I reckon it is going to look pretty stupid with 1200 mm rails in the Y, Pictures will follow.
    I do want to change the Z-Axis out for this but that will have to wait along time.
    Michael
  8. Kyo
    Kyo Veteran
    First Movement. :) Fail on my part the pencil was to soft and the graphite eroded away before finishing the drawing of the openbuilds logo. However the g-code seemed to complete without issue! I am running a very old dell tower running W7 and GRBL Panel V1.0.9.0a with a X-pro v2 controller.
    Peter Walker likes this.
  9. Razor_McT
    Razor_McT New
    Ta for the info on the Kress guys - sounds like a good option and seems to be available for around £150. I've been looking at the Chinese spindles as well and they seem like great value, but I'd be a little concerned about the weight.
    Any negatives on going for the Kress vs the Dewalt 26200?
  10. Razor_McT
    Razor_McT New
    Had a good look over it last night and nothing's loose - and the steppers seem fine (at least they can plot drawings repeatably with good accuracy). It just seems like the aluminium extrusions resonate a hell of a lot (seems worse at lower feed speeds), plus I found that the sound was being heavily amplified by the table it was sat on - when I lifted it off the table, it was much better. I think I'll plan on mounting it on an MDF baseboard and then have that sat on rubber corner feet.
    I suspect that inserting some kind of snug fitting rubber piping in to the hollow centres of the extrusions might help but that's something for another day.
  11. Razor_McT
    Razor_McT New
  12. dddman
    dddman Journeyman
  13. dddman
    dddman Journeyman
    By the way, I'm working on my own C-Beam machine on steroids :) Here's a preview:
    Kyo, GrayUK and Michael Shore like this.
  14. apburner
    apburner New
    Oh I like that. Love the linear rail mounting idea.
  15. Michael Shore
    Now that is just mouth watering, I thought about going square linear rail, but I could not find anyone at the right price point for me.
    I love the way it is so easy to mount the rail to V-Slot, I am stuck with 30 mm between fixings on the round rail, so I need 30x60 style extrusion if I want to mount it in line. I love and would like more pictures of the Z Axis if you would, and from the picture it looks like its a 8 mm TR screw what backlash are you getting on there?
    Love it, keep up the pictures.
    Michael
  16. dddman
    dddman Journeyman
    Contact me in a private message with the size you need and where you're from, I might have what you need somewhere :) (Well I just seen you're in UK... :p)
    I'll take more pictures tonight :)
  17. Michael Shore
    If you are stuck between the two just take a look at what the Kress can do, I found THIS.
    I chose the Kress as it was what robocutters were selling as a spindle for the C-Beam, glad I did now.
    Michael
    GrayUK likes this.
  18. dddman
    dddman Journeyman
    Here's some pictures of my build, the green parts and the mdf parts will be milled from aluminum, this was for test purpose only :)
    Michael Shore and GrayUK like this.
  19. Razor_McT
    Razor_McT New
    Wow, that is impressive and is big help thanks. Have you come across any videos of the Kress on a C-Beam milling aluminium?
  20. Razor_McT
    Razor_McT New
    Any sources for a reasonably priced mounting collar for the Kress 1050?
  21. Michael Shore
    I know of 2 people that stock a mount for the Kress
    Colin at Robocutters.co.uk
    and
    Brian at CNC4YOU.co.uk
    CNC4YOU will deliver next day if you get the order in before 2:00. they are very helpfull and always answer the phone.
    and when you are talking about the stiffness of the mount its not worth going cheap.
    for the collets, I used damencnc.com, they also do a mount for the kress but it mounts from the back, so not sure, but you probably would have to cut a new Z-Plate, look under tools.
    I have only found THIS video with a kress on a modified C-Beam machine, but I have not searched for that combination before, but I see plasma torch videos as well, the beauty of this build is you can do almost anything you want, you just have to have that small spark of an idea.
    Regards
    Michael
  22. Razor_McT
    Razor_McT New
    Thanks Michael, that's all really helpful info. I presume I'm probably just going to want to get a 4mm collet to go with the 8mm collet it comes with?
  23. Michael Shore
    I got 4 6 and 10, but I now wish I had also got a 1/4, 1/8 and my chamfer bit is 5mm.
    make sure where ever you get them from they come with nuts, Kress used to supply them separate, but it is recommended to keep them in the nuts, just get what you really need now.
    I use GBRengineering for the Endmills
    M.
  24. Bruce Fenstermacher
    I've been delayed for the last two weeks finishing my c-beam because a driver on my new XPRO controller failed. I've just gotten the replacement and wired it up exactly as Mark does on the build video. I'm using GRBL Panel as well. I purposely bought everything the same as Mark so I could duplicate his success with little experimentation.
    Problem is two of my axes travel opposite of Marks. I don't know if this was the case with the first board as I didn't get that far. And before I simply reverse wires on the motors, I'm wondering how this can be. Anyone have an idea why my build that duplicates Mark's to the T would be different?
    Mark instructs that we must reverse the Z axes wires and tells us how but also mentions it can be done it software. As it stands, my z axes is one that does not (currently) need to be reversed like Mark instructs. He saws motors can be reversed by swapping wires or in the software. I've not found anyplace in GRBL Panel to reverse motor travel. Is there a place to do this?
    Bruce
  25. Razor_McT
    Razor_McT New
  26. Bruce Fenstermacher
    Thanks Razor, that tells me how to fix it but does not explain why if I follow Mark's build video to a T with the exact same hardware and software that a fix should be required. I hate to apply a "fix" that masks something else wrong.
    It would also seem better to hard wire this fix rather that software which could be changed and the fix forgotten.
    Bruce
  27. Bruce Fenstermacher
    So I "fixed" the direction of the motors by swapping wires. But still curious why my setup would be the exact same as Marks with the same result he had in the video.
    Bruce
  28. Michael Shore
    Without knowing the motors, they just might be wired with 1 pair the wrong way round. but the main thing is you got it fixed.
    Michael
  29. Kyo
    Kyo Veteran
    I purchased the complete openbuilds kit. c-beam machine / motors / ps / ect.
    My wiring did not match the video exactly either. I did not mess with any thing software side ( grbl panel V1.0.9.0a ) I just wired in the motors to the x-pro as to get the same movement x-+ / y-+ / z-+ as Mark shows in the video and orientation jpg all seems well. I do not think it matters to much as long as each axis functions in the correct direction both positive and negative.
  30. Bruce Fenstermacher
    Thanks Kyo, at least good to hear I'm not alone buying the whole kit but not being able to follow the video exactly and get the same result.
    Bruce
