Bolt Size to Mount Stepper
Discussion in 'Motors' started by Project Hopeless, Feb 23, 2020.
  1. Project Hopeless
    I have Nema 24 steppers (24HS34-3504D). They call for M4.5 socket head screws which are difficult to find.
    I tried an M5 and it is really snug. any suggestion for a screw size, metric, fractional, or numbered?
    A #8 screw will be a little undersized (4.06mm) but it's probably as close as you're going to get and should work fine. If you're wanting to go bigger you can always drill out the holes in the stepper.
  3. Gary Caruso
    Personally I drill mine out for M5
    Gary
