Blank screen
Discussion in 'OpenBuilds Forum Help' started by Greg Emmons, Mar 29, 2021.
  1. Greg Emmons
    I just started a job using openbuilds on a windows 10 HP Pro Tablet. Everything is working right until but the control screen for openbuilds has gone blank. It’s just a white box. The job is still running but I can’t pause or stop it. How do I get the controls back without crashing my machine?
    Access the web interface from http://ip-of-machine:3000 for now, then once job is done a reboot should help
    May suffer. Meant for use on a PC with decent specs
  3. Greg Emmons
    What are the recommended specs? Thanks
    4GB of RAM at least
    WebGL capable GPU - white screen is usually a WebGL based issue
    Up to date chipset and GPU drivers
    With any less, you can disable features (eye candy) on the Troubleshooting tab under the Application Diagnostics if it keeps crashing on you
  5. Greg Emmons
    I can’t access the web interface by typing in my IP address :3000. It just gives me several suggestions of links. Thanks
    I used the ipv4 in ipconfig.
    Did you allow CONTROL through the firewall?
    Is the device running CONTROL on the same network as the device you are trying to access the URL from?
    Job done yet? If so, reboot
  7. Greg Emmons
    No the job will take 36 hours
  8. Greg Emmons
    I tried accessing it from the tablet. The firewall never asked for permission.
  9. Peter Van Der Walt
    On first run it would have - windows does not allow networking applications to start without prompting. Regardless, easy enough to add it now:
    How to Allow Programs through the Windows 7 Firewall - dummies
    If you have any 3rd party Antivirus/firewall consider them as well
    MaryD likes this.
